Question about Dryers
Gas dryer is running but not putting out heat
  • 82 Answers
MOST COMMUN THING IS THE THERMAL FUSE!!! CHECK IT AND REPLACE IT IF NECESSARY!!
Posted on Oct 05, 2009
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
I have a whirlppol gas dryer Mod-LGR7648KQ1 which runs but does not heat up. I dont know if it's a sensor, the ignitor or heating unit or even the thermostat. It's old and I'm not looking to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Whirlpool Dryers
The dryer will run but wont put out heat.
heatman101'
Jul 13, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Kenmore series 70 dryer that runs but does not put out any heat. What part(s) do I need to fix this?
heatman101
Jun 29, 2011 | Kenmore Dryers
Will not put out heat but will run? Help
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not put out any heat to dry but the dryer runs
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Whirlpool WED5300S Electric Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Maytag neptune gas dryer dryer will run but the igniter will only ignite part of the time, thought we had a bad igniter put in a new one, it lit up right away dryed one load completely dry, put in the next...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Maytag Dryers
The gas dryer won't stay heated up.
Do you have stacked clothes on top of it or anything else? If so remove those items and never put anything on there. it's not a table it needs to be clear so heat can dissipate from cabinet. IF that doesn't solve it write bac
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
