Question about Canon PowerShot G9 Digital Camera
When I use my tele converter, what dose the setting in the menu do? I don't see a difference whether I set it or not.
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
User Manual
I checked the Tamron website menu of manuals and one is not listed. This is a pass-thru device, so other than placing it between your lens and camera body, there should be no additional settings. Your camera focus and exposure is thru the lens so the camera should adjust seemlessly. Please tell us what the problem is, what lenses and body you are using.
Mar 07, 2014 | Tamron F Af Tele-converter 2x C-af1 Bbar...
How to get my canon A560 in postcard resolution
Press FUNC. Menu, go down to L (Recording pixels) then goto the right to the thumb nail with the mountains (Postcard) It is 2 places to the right of the default settings M3.
When you select the postcard setting you can't use the digital zoom or digital tele-converter.
Dec 27, 2013 | Canon PowerShot A560 Digital Camera
Mjpeg video wont work
I do not sure whether this can help you, this article mainly tell you how to convert mjpeg to imovie, but you also can convert to other format, good luck.
Oct 01, 2012 | Philips 32PFL3506/F7 - 32 Widescreen 720p...
Daewoo DTQ27U4SC volume is too low.
Check whether the set is in Hotel Mode. If it set so, you might have to enter its service menu mode to set it out. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily.
Aug 20, 2012 | Daewoo DTQ-20U4SC 20" TV
Ps2 to lcd tele set up problem
Look at the menu settings on your TV. Some TVs you can set the video to come in through AV (the red,yellow and white), and the sound come in through something else, like HDMI. You need to make sure the TV is set up to where all are on the same setting.
If that doesn't work, I would check and see if your AV cables from your PS2 work on another TV. That way you can rule out whether the problem is the TV or the cable itself.
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Got no instructions
1-The TV needs to be on channel 3.
2-On VCR remote set VHS/TV switch to VHS. (click it a couple of times until VCR channel shows on screen)
Dec 25, 2008 | Televison & Video
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
GPRS setup for Samsung Blackjack i607
Start--Settings---Connections---GPRS
Click at menu---New--- Connection name
Connects to The internet
access point name as provided by Tele provider
user name and password as by provider
ip address: as by provider
done
go to proxy
Connects from The internet
Connects to WAP network
proxy:port
type : http
Username and password as by provider
Kayshan98
Feb 03, 2008 | Samsung Blackjack SGH-I607 Smartphone
Canon PowerShot G9 Digital Camera Logo
13 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
