Question about Cyberhome CH-DVD 300 DVD Player
Yellow light on, dvd player won't open ch dvd 300
SOURCE: Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
Posted on Jan 30, 2007
SOURCE: Remote Codes
i need remote code cyberhome ch dvd 300 for rca control
Posted on Dec 30, 2007
SOURCE: Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
I have the same problem, but I know what the cause is. Mine stopped working right after we had a power failure, so I suspected a power problem. The +5V DC supply from the power supply pcb is only at 3V. I removed the wires for the +5V and patched in a USB cable to provide +5V and it is now working fine. I noticed that one of the capacitors on the power supply pcb is buldging on the top, so it's probably bad. I'm going to try to replace it and see if it fixes the problem. The simple answer is that your power supply pcb is not working correctly.
Posted on May 18, 2008
SOURCE: Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
Posted on Jun 07, 2008
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
Posted on Sep 25, 2008
Door won;t open
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Oct 28, 2012 | Cyberhome CH-DVD 300 DVD Player
Tip
Cyberhome CH-DVD 300 Manual Have you lost your Cyberhome CH-DVD 300 DVD Player...
Have you lost your Cyberhome CH-DVD 300 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Cyberhome CH-DVD 300 DVD player is available here.
I hope that helps.
on Apr 10, 2010 | Cyberhome CH-DVD 300 DVD Player
The light on the dvd player won't turn green any more.I can't get it to play any more. If I did get it to play it would say bad disc the light is now yellow not red are green any more.
hi,
You dvd have problem with its spindle motor. Spindle motor is one on which the CD rotates. If the winding of the spindle motor become short this problem can occur. you can see the spindle motor in the center of the mechanism. spindle motor will not cost a lot. Just replace the spindle motor your problem will solved.
ok
May 06, 2011 | Cyberhome CH-DVD 300 DVD Player
My Cyberhome CH DVD-300 DVD player continually displays a yellow light. It will not turn on, eject the cd or do anything at all and I cannot find my manual. I have a library rental movie in it that needs...
The Power Supply is not working properly, . The 2200 microfarad capacitor close to the 5v,12v output is most likely the culprit... Easy to replace, just get a spare from radio shack for about 2 bucks and if you know how to solder then it shouldn't be a problem...
Nov 26, 2010 | Cyberhome CH-DVD 300 DVD Player
Can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Sep 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Has a yellow light when plugged in but won't turn on. Won't open
Hi.That kind of dvd players have very small power circuit.And each of component on the board has to work properly .Especially the capacitors on the power board are drying out in the short time.First replace C10 capacitor with exactly the same voltage and farad value.(1500uf/16v for example).Than if you are able to replace more, do it as much as possible .
Jun 10, 2009 | Cyberhome CH-DVD 300 DVD Player
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
18 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
