Question about Garden
25 hp started using oil all at once. (1 qt an hour) Blue smoke coming out of exhaust. No loss of power. Left plug a little oily. Thanks, Jr.
  • 50 Answers
Probably a broken piston ring.
Posted on Oct 05, 2009
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
Why is my 2007 Nissan sentra 2.0 using 1 qt of oil every 600 miles?
More than likely u have a leaking valve cover gasket unless your seeing smoke than it might have a burnt valve guide or guides if its smoking real bad than it could have bad rings and you don't want that cause then u half to tear the motor down basically rebuilding the motor
Nov 11, 2014 | 2007 Nissan Sentra 2.0 SL Sedan
What does white smoke coming from exhaust of a 01 'suzuki gsxr 1000 mean when starting only?
For motorcycles with 4-stroke engines: The white smoke from the exhaust means that the engine oil is leaking into the combustion chamber where the petrol burns. ... This eventually means that you have to get your piston changed along with the piston rings that prevent the engine oil leaking into the combustion chamber.
Mar 14, 2017 | NiceCycle Cell Phones
2001 saturn sl2 blue smoke when starting I'm car
Blue smoke is usually bad rings. But in the meantime, try changing your oil, see if that helps.
Mar 11, 2012 | 1993 Saturn SL2
Burning 1 qt oil 2007 grand caravan sxt per 1000 miles. changed pcv vale still happenung
Is it really burning it, or just losing it? If you have blue smoke coming out your tail pipe, and oily black spark plugs, there's really not a whole lot you can do about it short of a rebuild of your engine. It really sounds like a rear main seal leak, or a faulty oil filter.
May 07, 2011 | 2007 Dodge Grand Caravan SXT Minivan
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Exhaust pipe comes out white smoke when start bike on side stand
Continuous or just for the 5-10 seconds.
If continuous you may have oil seeping past your pistons oil rings or valve guides oil seals.
Check your spark plug see if they are fouled badly (covered heavily and oily) or just covered by oil and sooth lightly.
If 5-10 sec it is normal as the engine is heating up there are normally a little oil seeping past the seals.
Apr 10, 2010 | 2004 BMW R 1150 RT (ABS)
1.9 dci no power and bluey grey smoke is coming from the exhaust
There are indeed traces of oil coming out of the exhaust. Blue smoke is burning oil. Grey or white smoke is usually coolant/water going through the engine. This can be caused by leaking head gaskets, valve guides depending on the engine, excessive blow-by, etc. Large amounts of oil are not good; and water is even worse. I would look at getting the head gasket replaced. The loss of power is because neither oil or water likes to burn, and once your engine clears it out, it probably runs ok for the rest of the day. Then I'm guessing the next morning, it comes back. This is an urgent fix, because prolonged leakage can damage the engine block, head, or both.
Oct 19, 2009 | Renault Sport Cars & Trucks
Very heavy smoke from exhaust of Yamaha Virago 250ccobviously smells of burnt oil.doesnt seem to have any rattle or loss of power just belches out blue smoke.
give the air filter a blow out m8,, and change the plugs to a hotter grade,, ie if u have ngk b8es or summat try b9,,that type of thing,
Apr 10, 2009 | 2000 Yamaha Xv 250 Virago S
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
