Question about Garden
My Craftsman leaf blower will not start. Why not?
It is gas powered with fresh gas and a new gas filter and spark plug. It was very difficult to start last year. When I could get it started, it would run okay until I shut it off to re-fuel. Then it would be very difficult again, until finally, it would not start.
This year, I could not get it started at all. It barely turns over when pulliong the pull start rope.
What could be the problem?
Thank you very much for any help you can give me.
  • 148 Answers
Inside the carb is yet another fuel filter in the form of a screen. It is located just under the inlet needle and it would be included in a carb REBUILD KIT (not simply a diaphragm kit).
Replacing the screen and rebuilding the carb take nearly the same amount of labor so buy yourself a kit. Roughly $10.00 for most Hand-Held blowers.
Hope this helps.
Posted on Oct 05, 2009
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Dec 02, 2016 | Craftsman Garden
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Craftsman leaf blower starts and then stalls
ckeck fuel filter fuel lines and fresh gas, then clean carb and or rebuild it, also check primer bulb for function hope this helps., check exhaust muffler screen for being plugged
Apr 15, 2011 | Garden
Sears Gas powered blower 25cc/1.5 Cu. in 2 cycle 200 MPH/400 CFM Where's the fuel filter, so I can clean it?
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Jan 23, 2010 | Craftsman 4 Cycle Blower/Vac
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Craftman leaf blower,not starting,fresh gas,new
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Apr 22, 2009 | Craftsman Blower Attachment
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
I can't start my craftsman leaf blower 8 months. what could be wrong.
empty the gas out, put in fresh mix , clean the plug or replace it , clean the air filter. and if it still doesnt start use some starting fluid in the intake. then let me know if it starts
Mar 20, 2009 | Craftsman Garden
Garden Logo
402 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
