Question about Boating
Fibreglass repair to boat: deep scratches from low speed impact. step by step repair required.
    Sergeant:
  • 302 Answers
Go to www.youtube.com and search for fiberglass repair
Posted on Oct 06, 2009
I have a 1989 procraft fiberglass bass boat I want to know if top can be removed and how
The two halves of a fibreglass boat are usually permanently joined in manufacture.
A bead of structural adhesive is applied and the two halves clamped together until fully cured. The adhesive is tough and similar to that used to glue in car windscreens.
Feb 05, 2018 | Boating
Do you have a glue I can fix a crack in fiberglass
Yes there are glues and sealers that will repair fibreglass though for an effective repair the crack should be ground out to a vee and a hole drilled at each end in the normal way.
If the area to be repaired is not stressed and the crack is small impact damage a reasonable temporary repair after preparation could be made with a structural polyurethane adhesive sealer, similar to that used for bonding windscreens.
If the crack is stressed it must be properly prepared and filled with fibreglass repair paste and then reinforced with layers of random mat and resin and finally woven mat for a reasonable finish.
Nov 17, 2017 | Boating
Can a cracked BBC/fibreglass bathtub be repaired?
beautiful new bathtub and wall right over your old one
or contact a good fiberglass repair shop (boat repair place might be able to help)...
Aug 10, 2017 | Washing Machines
Weight of 17 foot fibreglass boat and 115 horsepower Yamaha motor
the weight of the motor will be obtainable from the Yamaha web site in the specifications section the weight of the boat is any body guess as you didn't give a manufacturer name
most marine shops will get close as they are familiar with boat constructions and supply trailers to suit
Aug 01, 2017 | Yamaha Boating
Repair of small crack/cut in the hull bottom...3 " long..1/64" or less wide...
It depends on the material of the hull. If it is Fiberglass then buy a small auto or boat repair fibreglass kit and follow instructions in the kit.
. If it is one of the engineering thermoplastics like High density Polyethylene ABS or Polypropylene I would try and find somone who can weld it with the appropriate material. This would be done by carefully shaping the plastic away from the crack to form a "V" shaped recess and then filling the gap with the appropriate filler rod usually using a hot air blower designed for the job.
Jun 02, 2010 | RTO Pelican Monaco Pedal Boat
Moving the steering from aft to forward on a runabout
There are a couple of options. If you forgo the steering wheel I know that Johnson and others make a Tiller extender. I have been able to move up a seat in a 12 foot boat using this. On my motor the speed control was on the Tiller handle. Still had to jump back to use gear shift.
The oldstyle controls used 2 cables and pulleys to steer wheel. You will have a time to find short enough cables to do motor RPM and shifter. Then you will need to mount steering wheel to something to turn it.
There are Salvage yards for Boats just like there are for cars. Do an internet search for your area. Then pull your boat there and explain what you want to do. Look under Marine Salvage, Marine Salvage yards.
Mar 07, 2010 | Boating
Osmosis in the hull
Osmosis in the hull is a fair amount of air in the glassing,when the hull was laid up.You will have bubbles coming through in the fibreglass that is fixable.Each bubble need to be ground out to good glass.The layers will most probably be chopped strand.Grind back untill clean non frosted/no aired looking fibreglass is found.The refill is 2 diff. choices.Cheaper is an epoxy 2 pak car bog and the other is vinyl easter fibreglass.Epoxy 2 pak,buy a very good grade and than 2 ways to do the finish color.Easiest is a touch up 2 pack paint,harder is a gelcoat paint and match-up.I would go the grind back,epoxy filler and 2 pak touch up paint.Hope this helps
Jan 26, 2010 | Boating
How to repair an open split in a royalex canoe
key the surface using sandpaper to make it rough, and apply a fibreglass matting repair. They are available in kit form from canoe outfitters, often sold a kicker plates.
The application is very simple, just follow the kit instructions.Be aware though that the boat has to be perfectly dry before you start. (leave it indoors for a couple of days first) I often use a hairdryer on the surrounding area for a few minutes beforehand to ensure no moisture is present. Be careful not to get the area too hot though, you don't want to melt your boat!
Once the kit is applied and has set you can smooth the edges down with a sander.
Aug 09, 2009 | Boating
Boating Logo
212 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
