Question about Olympus Stylus 770 SW Digital Camera
The camera is 2 years old, when turning on the power it goes to the date set,you can change the year, then it slides over to the month, but seems froze up, then the camera resets itself, if you skip the date set up, it shows a view on the lcd, but can't take a picture, and the camera resets again. My son borrowed it and took pictures snorkeling, so it may have gotten wet, but the lcd screen is not distorted as it was a year ago when I got water in it.
SOURCE: blurry pictures
As suggested above, you may be shooting without adequate lighting. In that case the shutter would remain open long enough that even the smallest hand movement would result in a blur.
Posted on May 18, 2007
SOURCE: pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Posted on Aug 26, 2007
  • 3 Answers
SOURCE: Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Posted on Sep 06, 2007
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know underwoodman@gmail.com
Posted on Feb 26, 2008
SOURCE: my camera wont take pictures card read error
I took a pictures with my camera and now some I cannot view some of the pictures it says Picture error
Posted on May 19, 2008
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Nov 21, 2010 | 2009 Chevrolet Cobalt
Forgets date / time every power off/on
Yes there is and about two years is the right time for it two be losing it's power. Check on the right edge of the body and the left edge of the body, there should be a small slide out compartment for a button battery.
Sep 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I need to set time n date. I have no manual. How do I set time & date?
power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
Jun 26, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
Date and time change
First you press the button called "MODE" and, without releasing it, press the "SET" button.
Then, the year will start to blink.
Set the year with the "SET" button. Once you finish setting the year, press the "MODE" button to change to the month.
Then, the same way with the month, day, hour, minutes.
After minutes, the display will stop blinking.
YOUR SET!
Dec 08, 2007 | Olympus Stylus Zoom 140 Deluxe 35mm Point...
Date and time
Nov 07, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Olympus Stylus 770 SW Digital Camera Logo
20 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
