Question about Asko T701 Electric Dryer
Need to replace the belt on the asko t701 what is the difficulty level doyou have a diagram
  • 93 Answers
NO DIFFICULTY- PUT THE BELT ON THE SMALL PULLY FIRST IN THE GROOVES AND ROLL THE LARGE PULLY AROUND A COUPLE OF TIMES TO POSITION THE BELT
Posted on Oct 04, 2009
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
What does the code C3 mean on my Asko Dryer
Asko electric dryer model T701 has timer-controlled drying in addition to the two automatic (thermostat-controlled) programs. Without electronic, there isn't possible display fault code.
Dado
Sep 26, 2014 | Asko T701 Electric Dryer
How to replace belt on asko t701 drier
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel (see page 26).
2. T720/780: Remove the external fan housing (see page 32).
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws._____________________________________________________
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
Dado
Sep 22, 2014 | Asko T701 Electric Dryer
We have an ASKOT701 electric dryer with a broken belt. Can we replace this ourselves?
you may be better getting asko to replace it,they can be difficult to get back together
Jun 05, 2010 | Asko T701 Electric Dryer
Need wiring diagram for ask t701
wiring diagram for akso dryer T701
May 02, 2010 | Asko T701 Electric Dryer
My dryer is not spinning
change the belt if you need help get the belt first thank you please rate me
Mar 12, 2009 | Asko T701 Electric Dryer
Asko T701 Electric Dryer Logo
386 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
