Question about Sanyo DS31590 31" TV
Sanyo T.V. My Sanyo T.V. was working great - wonderful picture, sound everything. When I went to turn it on today nothing. It is like it is unplugged, I checked and it was plugged in. I have been checking on the internet and have found out that this is not a uncommon thing to happen to a Sanya T.V.. but don't know if it can be fixed or if it would be to enpensive to fix. Anything you can tell me would be greatly appreciated.
  • Blonday4c Dec 23, 2007
    Thanks to your advice- to check the fuse. We did today and it was blown. Went to Radio Shack and using the number on the fuse 4A125V bought a pkg. of 125 Volt fuses for about $3.00. Came home and replaced it and to our great joy the T.V. worked Our Sanyo is 1996 31' Thank you again. What a wonderful Christmas present.. .
  • lnjam Dec 28, 2007
    Sanyo DS35590 I had the same problem, removed the back and checked the fuse - OK. I did not find any brown spots olyn dust! Still not able to get it to work. If it is the transformer, are they expensive to replace? or should I buy a new tv? Thanks for your help!
    Sergeant:
    Champion:
  • 362 Answers
Take the back off the tv and where the power cord hooks into the tv check the fuse there on the board if this isnt blown then you are probably looking at a power supply problem look at the board for anything that looks black and burnt or dark brown spots on the board. this will tell you where the problem is if it has any. but it just might be the fuse.
Posted on Dec 22, 2007
I have a Sanyo FVD48p4 that has suddenly stopped showing the picture, but there is still sound.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 19, 2017 | Sanyo Televison & Video
Sanyo DP50710 50'' plasma TV turns on power light then turns off/ on on its own. No picture. After checking all fuses and capacitors, we installed rand new power supply board. Still the sa
The set will need to be professionally diagnosed. There could be a # of things causing your problem. Playing the guessing game can get quite expensive.
Sep 23, 2012 | Sanyo Televison & Video
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
Jul 23, 2009 | Sanyo Refrigerators
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sanyo DS35510 35" TV Problem
the red gun or the video driver ic went bad, nothing you can do alone, if the red gun went bad you will need to replace the crt wich is too expensive
Jose
Aug 13, 2008 | Sanyo DS35510 35" TV
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Sanyo DS31590 31" TV Logo
110 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
