Question about Acer Aspire 5610-4648 Notebook
WHERE DO I TURN ON MY CAM - Acer Aspire 5610-4648 Notebook
Camshaft would not turn anymore can't make it to the timing mark how do I turn it to the timing mark
Not knowing how far your cam timing is off, your valves may be hitting the top one of a pistons. That may be why cam wont turn anymore.
May be best to back up the cam a bit, remove the spark plugs & with screw driver or wooden dowel probe the cylinders to see which piston is near the top.
Then rotate crank a bit to lower piston down the cylinders DO NOT USE STARTER to rotate engine while timing belt is off or valve damage may occur.
Jul 16, 2016 | Cars & Trucks
Ssangyong Korando 2.9tdi
If the engine cannot turn by hand with the cam removed then it is a problem on the crankshaft or con rods. It could also be water on top of the pistons that cannot compress. Remove the injectors and see if the engine will turn a full circle. if water comes out remove the head and check the gasket or head for cracks. Please reply if it is a single or dual cam.
Dec 04, 2013 | SsangYong Korando Cars & Trucks
Intake cam does not turn **** exhaust cam does turn gear slips on exhaust cam
Your cam is either not installed correctly or the timing chain is broken. The gear on the cam shaft may not be seated correctly with the Key or the key has sheared off allowing the gear to spin instead of doing it's job.
Mar 25, 2011 | Ford Taurus Cars & Trucks
My car wont start but it will turn over. i thought it was the starter i replaced that. mabey you can suggest another solution thank you
You should check the cambelt timing.Take plug no 1 out. Put your forefinger over the plug hole. Turn the engine until you feel the compression coming out of the hole. Turn the engine slowly with your hand until the piston is in the top position. Use a long screwdriver in the plug hole todetermine that the piston is at the top position. Remove the tappit cover. The camshaft should then be in the position where the inlet and outlet valves on piston no 4 wants to open and close when you turn the camshaft. If that is the position, your cambelt timing is correct, If not, Remove the belt off the cam pulley, turn the cam so that on piston no 4 the cam wants to open and close both the inlet and the outlet valves . When you turn it to the left, the one valve wants to open and when you turn it to the right the other wants to open. Put the cam exactly in the centre and replace your cam belt but make sur that your piston no 1 sta at the top. Your cam timing should now be 100% and your car should start if it gets petrol.
Jan 19, 2011 | 1989 Honda Accord 4 Door
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
I am a kid and i don't know how to turn on my web
The Acer bar should be at the top of the screen when you start the computer. Look for the cam icon on it.
If the Acer bar is not showing on your desktop, Go to start , Programs.Look for "Acer web Cam": or something close to that
Dec 21, 2009 | Acer Aspire 5610-4648 Notebook
How do i time my 1993 cbr 600 f2? and how do i put the cams and cam shaft inn?
remove the inspection cover in the right engine case turn the engine clock wise to no 1 tdc remove the cam chain tensioner line the marks on the inlet cam inlet then a line flush to the head then ex cam line flush to the head torque the bolts in a criss cross 12nm turn engine a full turn check that it all lines up then turn it over by hand to make sure it turns ok
Sep 28, 2009 | 1993 Honda CBR 600 F(2)P
When i roll engine to TDC the cam shaft markes are on the bottom of cam shaft sprocket
Turn the crank shaft ONE more full turn and check the cam marks again.
Sep 12, 2009 | 2000 Dodge Intrepid
I cannot turn the web cam on
There is a software to turn on the webcam
Try this
Start > Start Search > type in YouCam/Cyberlink/MediaSmart.
Click on any one which you see in the start up menu above and your webcam will start.
Jun 03, 2009 | HP Computers & Internet
Valve timing
hello
ok to start intsall by putting the proper cams in their proper spots. they should be marked "FR IN" for front intake "FR EX" for front exhaust and so on. the caps should be marked as well. then tighten them down in a crisscross pattern at 15ftlbs. be sure that the cam journals were lubed before install as well. this will prevent siezure. if both cam sprockets were removed, install the front cylinders cam sprockets first. remove the crankshaft timing hole plug on the left side crankcase cover. and the crank bolt access plug as well. turn the crank counter clockwise till the marks FT notch aligns.
install the cam sprockets and cam flanges so that they read as follows. the timing marks FI for intake and FE for exhaust are flush with the valve cover gasket surface outwards opposing. then align the cam bolt holes while lobes are facing upward. you can then turn the crank counterclockwise to install the bolts. then you can remove the cap bolts to install the cam chain guide plate and instll it.
for the rear. turn the crank so that you see the same timing marks as mentioned earlier. with the crank on the FT position. and the cam sprocket marks to the outside flush with the gasket surface.
next turn the crank counter clockwise 3/4 turn or 270 degrees and align the RT mark in the flywheel inspection hole. then you will install the cam sprockets and chain and cam as the same as you did for the front.
i hope this helps. thanks
Mar 19, 2009 | 1999 Honda VTR 1000 F Firestorm
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
