Helloo about toshiba e studio45 i have error code CB1 , this machine is a secound hand and when it desplay the service error it shows the contact number for the maintenance i need to remove it too but i dont know how !!!! thank you
Thanx haydnwil ,,,
i already tried this but the same nothing happen still have the same problem, i wonder if there is a way to reset the finisher setting (Zero point)
thanx
Posted on Oct 25, 2009
    Problem Solver:
  • 15 Answers
This is a finisher error code.
turn off power then grasp the lower tray of finisher on both sides and shift up as far as it will go. turn power back on and see if that works. worse case disconnect the finisher from top rear of machine-at least the copier should still work and copies will go into middle.
Posted on Oct 16, 2009
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
Call for service C413 toshiba estudio 2006
Here is the verbage for the error code at this link
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%202006&code=C413
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 11, 2016 | Toshiba Office Equipment & Supplies
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
AEG L87480 on desplay makers E91 what means
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Jan 11, 2016 | AEG Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
F7 CODE
Unfortunately your microcomputer has to be replace ,
check out Google web site
Mar 12, 2013 | Whirlpool GH9185XL Microwave Oven
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Toshiba e-studio45 error
you need to hold down the "c" button to get actual code A*** through G***
Dec 24, 2008 | Office Equipment & Supplies
Hi this is messay from ethiopia
where has this error appeared? ie. is it on the screen of the copier? is the spanner showing? did it print out the error when you try to print from the computer?
May 07, 2008 | Toshiba E-STUDIO 211C Copier
MJ-1007 Finisher - CB1
Check the stapler unit, it is most likely the problem
Nov 17, 2007 | Toshiba e-Studio65 Copier
jasbo
jasbo
