Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Dell 1704 FPTt monitor goes black after about 20 min
My monitor goes black after about 20 min anything I can look for?
  • 1 more comment
  • Anonymous Nov 30, 2008
    I have the same problem but from what I can find in my research this is caused by a faulty inverter that controls the LCD backlight...
  • Jonathan James
    Jonathan James Feb 22, 2009
    Once the monitor goes black, if I turn the power off and then back on, it restarts long enough that I can read the screen. The black again.
    How do I repair the inverter????????
  • jfos5553 Apr 23, 2009
    Where do I obtain an inverter for the screen backlight?
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Posted on Dec 22, 2007
Screen goes black or pixelates
viewsonic va1703w screen is starting blur and it is changing colors Screen goes black or pixelates and after 15 to 20 mins by pressing the power on button of the monitor it is getting switched on, and again when restarted it is having the same problem.
Aug 18, 2013 | Dell Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
How un lock osd manu dell lcd 1704 fpv
Press the menu button and keep pressed for 20 seconds or untill OSD unlocked message come and same procedure for OSD lock.
Aug 20, 2010 | Dell 1704FPVs 17" TFT LCD Flat Panel...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
I have a Dell 1704 FPTt monitor and it is about 4 years old. The monitor will be fine for a few hours and then go black. I turn it off and back on and the screen only stay's lit for a few seconds. What do...
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the newone the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 26, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor goes black after being on for about 20 minutes
This might be related to your system power options, if your monitor turns off after sometime (20 mins in this case) the best way to find out if this is caused due to a thermal reason - is to see if the monitor can work immediately after it turns off (coz, for thermal shutdowns it needs time to cool down before it works again)
Sep 02, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell Ultrasharp 1800FP Power Saving Mode
go to control panel>power option>power scheme.
adjust the hard drive to 30 mins and everthing else 20 minutes.
also, go to display and adjust the screen saver to be longer. up to 9999min.
Jun 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
No picture
There is a good chnace your Backlight bulbs need to be replaced.
Oct 24, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
764 people viewed this question
Alun Cox
