Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
I've got a Honey Laquer(tweed) deluxe.Bought it new about three years ago. While it's powered up, there's a whine sound coming out, almost like a mid frequency feedback that doesn't change with the volume on clean channel and sometimes goes away temporarly with the drive channel buttom in but it comes right back. Gets louder with the master volume though on drive channel. Played maybe 30 gigs with it but never roughed up or dropped. Any help would be great. Phil at pcarias@carolina.rr.com
  • Fender Master
  • 5,603 Answers
I suspect a bypass capacitor for the preamp section has failed. It needs to go to the shop and be tested with an oscilloscope to pinpoint the problem.
DO make sure the feedback is NOT from something you have plugged into it... make sure it is there with NO input cable plugged in. Often external devices can introduce ground loops an noise like this. Lamp dimmers (even stage lighting dimmers) can be a source of interference.
The sound you hear MAY not be the full loudness as the oscillation MAY be above your hearing range. This COULD cause overheating and damage so get it fixed before using.
Posted on Oct 05, 2009
I have a '93 Fender Blues deluxe tweed and don't seem to have any reverb, am I missing something?
Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
Oct 16, 2016 | Fender Music
Why is my Fender Blues Deluxe Amp making a crackling sound without an instrument even plugged into it and when I do plug in, it quiets when I touch any place on the guitar?
You probably need a new input jack on the amplifier. When they get loose the connecting wires can crackle, but plugging a guitar in stabilizes them (no more crackle).
Feb 11, 2015 | Fender Blues Deluxe Reissue Tweed Combo...
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
I`ve just bought a new Fender Telecaster Deluxe. When I plug it into my amp there`s a slight hissing hum. When I touch the strings it stops. I`ve tried it through a different amp & changed leads so
you may have a ground loop problem and when you touch the strings you complete the ground loop so the noise dissapears. make sure the amp is plugged into a proper grounded outlet. also there is an aftermarket ground plate that goes under the pick guard. that is what I put on mine to cut the emf way down. if you bought the guitar from a dealer take it back to the store and ask them why you are getting so much noise.
Nov 26, 2011 | Fender American Deluxe Telecaster
I purchased a Passport 500 less than one year ago, used it maybe 10 times and recently turned it on to use and it would not power up. No lights nothing. Checked the fuse ok. Tried a new fuse nothing. ...
Check that the power cord is seated completely. These are hard to work on and if there is a failure in it, it is unlikely you will get it restored in time. I would suggest renting a system until you get it repaired. You need rent only a powered mixer with suitable cables as your speakers should be fine. The way the Fender Passport is packaged makes them difficult to work on.
Jan 11, 2011 | Fender Passport Deluxe 500watt Sound...
My Fender Blues Deville 212 has a very "ratty" tone on clean...
i am guessing on what the problem is , the post is very vague. i am guessing a channel switching issue. you need to check the "sugar cube" looking power resistors solder welds. they are probably cracked and arent making good contact. if you tap on the amp it will cut in and out, its probably these two resistors. they are usually 470ohm 5 watt cement resistors. what happens is they get real hot, and as they cool down they crack the little solder welds. i usually replace them with new and keep them floating up over the pcb to help them stay cool and off of the board to prevent further solder weld cracking, stock they are real close to the board. then put a little silicon under the resistor to hold it in place and to keep it still on the board. i just fixed a blues deluxe with this issue. while you are in there, cut out the resistor sitting right behind the reverb pot, this will make the reverb awesome. also solder the mid pot center leg to the mid pot leg that comes off of the bass pot leg to get better midrange control. very easy mods. check the master volume pot, is it a B100K? pull it and put an A250k in its place for better volume control. bias pots , etc. check my website yostamplifier.com.
Mar 05, 2010 | Fender Hot Rod Deluxe Guitar Combo...
No sound from speakers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Dec 15, 2008 | Fender Passport Deluxe 500watt Sound...
Sounds like only one amp is working. Then after a few minutes the red light goes on and the unit shuts down.
90 % of these types of problems are caused by faulty leads .... make sure that you have correct speaker cables and not just a regular guitar cable
Nov 08, 2008 | Fender Passport Deluxe 500watt Sound...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
104 people viewed this question
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
