Question about Timex Watches
Timex watch (indiglo wr30m) loses time.
The watch loses about 5-10 minutes per day. how can i make an adjustment to the watch.
escapement
  • 2334 Answers
SOURCE: Timex Expedition speed
It's not ok. Usual specs are +/- 1-2 secs a month, no more.
Try battery change first and if it doesn't help, go and see your nearest watcmaker to solve the problem.
Posted on Dec 21, 2008
  • 110 Answers
SOURCE: Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Posted on Dec 06, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
  • 2501 Answers
SOURCE: hourly chime
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Posted on Feb 25, 2010
To open watch case, hold back of watch up with arrow pointer on the back plate pointing to the right. There is a pry point on the upper edge where you will see a small arrow pointing. Use a small flat end screw driver to pry the watch case open. Be sure to replace the back the same way with the arrow pointing away from the setting knob.
Take a 1-1/4 inch paddle bit and drill a hole in a 1-3/4 inch wide piece of wood about 1/8 inch deep. Then take another piece of wood about 2 inches long by 3/4 inch thick by 1 inch wide to lay across the back of the case plate. Place the crystal of the watch in the drilled hole. Used a vise or clamp with the watch between the two blocks of wood to press the back on. Be careful not to over press. Works great
Posted on Jun 05, 2010
Replaced battery on Timex Indiglo WR30, now it loses time. Second hand hangs uo when it reaches area between 11 and 12, then continues on seemingly ok
need to put in fresh battery I know you may have just bought new one but it is old check for date on back package
May 13, 2017 | Timex Watches
How to remove stem on timex indiglo WR 30M ?
Insane as it seems, apparently the Indiglo wr30m watch stem does NOT have either a set screw or a release button. No vice needed though, just good fingernails. Pull it out one click to the 'set time' position and pull it out some more and it comes out.
Mar 06, 2011 | Timex 27191 Wristwatch
How do I change the day on my Timex WR30M Easyreader Indiglo watch. I can change the date, but not the day of the week. Help....
When you bought the watch, did you find a little manual in the packaging? The manual has all the info.
Dec 19, 2010 | Timex 27191 Wristwatch
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
Hourly chime
manual download"
Feb 25, 2010 | Timex Indiglo Analog Watch
Alarm on timex indiglo won't turn off
It's just a cheap watch, one hit with a hammer and the alarm stopped.
Jan 18, 2010 | Timex Expedition 84601 Wristwatch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 | Watches
Watches Logo
330 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
