Question about Hotpoint TDC32 Electric Dryer
It makes a constant squeaking noise
My hotpoint tdc32 tumble dryer works ok but it makes a constant squeaking noise. Does anyone know what is causing this and how i can stop it. Cheers.
  • 6,784 Answers
In most cases, this will be a worn idler pulley. I would inspect this pulley for excessive clearance.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Oct 04, 2009
  • Hotpoint Master
  • 744 Answers
Try looking at the bearings
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Posted on Jan 12, 2015
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Bad noise coming from dryer,i changed the belt and still have a noise..help
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Hotpoint TDC32 Electric Dryer
Machine making grinding noise when turning
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 12, 2010 | Hotpoint TDC32 Electric Dryer
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint tdc32
How do I put a new belt on my tumble dryer
Nov 08, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Dryer makes a noise like plates sliding
Could be coins in the drum.  Might also be a bad roller bearing.  Hard to tell.
Nov 06, 2008 | Hotpoint TDC32 Electric Dryer
TDC32 making a strange noise when running
sounds like bearings on your tdc32
Dec 11, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
402 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
