We just had a full split system installed. I am
We just had a full split system installed. I am getting a cold air leak from the cabinet that contains the coil. Should this part of the system be well sealed or is leakage of cold air normal?
    Problem Solver:
  • 10 Answers
That part should be well sealed as well as all of the air system. Leaks in the air duct reduce system efficiency.
Posted on Oct 04, 2009
Kelvinator a/c blowing out room temp air on hot or cold
Could be a few things. Is the outdoor unit running? If not, it could be an electrical problem is sensors, control board, wiring, maybe the settings are nor right on the remote. If the outdoor is running and its still not blowing hot or cold, it may have a gas leak.. I have made these assumptions that it is aKelvinator split system? 1 easy attempt that you can try is a full system reset. Turn off the machine at its isolator (usually next to the outdoor unit) or at the Meyer box. Leave off for at least15 mins. Turn back on and see if it works. Good luck
Dec 03, 2014 | Heating & Cooling
I have a split system air conditioner that quit blowing cold air
either the compressor is not running or you have a leak and are low on freon. the outside fan running does not tell you the compressor is running.
Jun 18, 2014 | Coleman Outdoor Split System Air...
Maytag washing machine model a 210 (1982) leaks above filler. how do i get into cabinet to check natureof/cause of leak?
see this cause and fix it:
During fill only
air/gap deformed or crack , replace see the diagram
the rubber tube run between water inlet valve and air gap can cause leak +inlet spout can be crack cause leak replace.
During drain and spin only
inspect main drain hose and fix it. steel or plastic outer rub can be rust,split if this happen you must replace the entire outer tub.
All the time
check the hot and cold hoses water tighting or replace
main tube seal leaking
pump defective leaking.replace
outer tube, split , rust, causing leak, replace
see the diagram
God bless you
7_19_2012_7_39_57_am.jpg7_19_2012_7_40_20_am.gif7_19_2012_7_40_43_am.gif7_19_2012_7_41_02_am.gif
Jul 18, 2012 | Maytag Washing Machines
On our 2005 Town and Country, the heater does not heat up for a long time, then it gets hot and then cold. Occasionally the temperature gage goes to warning light hot but this is about once every 3 to 4...
I assume you have checked the cooling system to ensure that first, that it is completely full of coolant (not just the overflow tank) and second that there are no leaks anywhere. Your description indicates either low coolant level and/or air locks in the cooling system. Only check coolant level when engine is cold. If it needs topping up, add coolant and then run engine at idle with heat control on full, until it reaches operating temperature, topping up as necessary. Allow cooling fans to cycle on and off a few times to ensure all air is purged from system. If coolant was low, then check regularly when engine is warm to see if you can find where the coolant is leaking. The places where the hoses connect to the metal pipes around the engine are the most likely points of leakage or a hose could have weakened and split.
If coolant level is OK and there are no leaks then it could mean a faulty water pump.
Nov 26, 2010 | 2005 Chrysler Town & Country
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
I have a mr slim model PUY-A18NHA3 Mini split. it is completely installed however it will not get cold it blows room temp air. I have checked for leaks and have none. i am not sure why it will not get...
You need to check the protection for the compressor has not failed. Other causes can be thermostat / pressure switch Low gas pressure Maintenance codes - any showing? Operator settings - timer/sleep/fan only etc..
Aug 03, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Turbo air not blowing cold air
10 minutes?? So he added the gas and jumped in his truck and left?? WHAT COULD REALLY HAVE HAPPENED?
Feb 23, 2018 | Turboair TAS-24H Split System Air...
Does not heat or cool
Hi, If the outdoor unit is running, make sure the fan is on also. If the system is new and has just been installed, it sounds like you may have a freon leak and have lost all its freon. Turn it on cool and let it run for a few minutes. Go outside and grab hold of the larger copper line coming out of the unit. It should be nice and cold and sweating. If not, and the fan and compressor are up and running, you have a leak and lost its charge. Check this and get back to me and let me know what you have found. We can go from there.
Shastalaker7
PS, When these installers put these units in, they sometimes get in a hurry and there welds are not very good and will leak over time, just to let you know.
Jan 26, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amana ultron 12 seer 2 yrs old compressor does not work blows cool air not cold
is it a split system? majority of problems, lets say 95% occur during install, u may have a leak! A pinhole at that, but maybe installer missed it, your out of labor warranty, call a 3rd party contractor and have them inspect it!
Aug 06, 2009 | Amana Comfort Zone 12M32PBEH Air...
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
