Question about Poulan Garden
How do I reinstall the chain brake on my Poulan Wild Thing??
    President:
  • 2,220 Answers
Find your model number add a LE suffix (i.e. if 2375 make it 2375LE) the "Handle, Chassis, and Bar Assembly" shows what detail is available. If not enough detail tell Poulan! Maybe it will improve for the next guy. If not happy with Poulan answer tell Husqvarna (parent company).
An entire new clutch cover (2375LE Type 2) item 36 pn545139903 is $19.43.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Sorry to not be more helpful but this is all we can do. HTH
Lou
Posted on Oct 05, 2009
  • 3 Answers
There are actually many people asking the same question on this site with regard to several different saw models and none of the answers have been very helpful....until now.
I was faced with the same dilema and finally figured it out. When you try the steps below, you'll kick yourself for not having thought of it sooner.
If you are like me, my saw just quit. The engine would start, but the chain wouldn't turn. I didn't really know what a chain brake was or how it worked. Since I tinker with things, I thought I would take the saw apart and see what I had broken. I started by loosening some bolts and prying off a metal band from around the flywheel/sprocket assembly. Before I knew it, I had taken off the brake. I then realized what the chain brake was, how it worked, and I had actually not broken a thing - I had only needed to reset the brake. Now, however, as I tried to re-install the brake, nothing would line up and it seemed impossible.
Here is the trick:
1. Take out the c-clip and remove the flywheel/sprocket.
2. Push the brake handle to the forward and locked position.
3. Assembly the brake spring/band/cover assembly back into place over the end of the brake handle. Without the flywheel/sprocket assembly in place, you should be able to easily manipulate the springs so that things align correctly.
4. Install the brake screws.
5. Pull the brake handle back to the unlocked position, thereby opening the band.
6. Reassembly the flywheel/sprocket assembly.
7. Reinstall the blade bar and chain.
8. Replace the cover.
Hope this helps. To all you yahoos who said by a new assembly or look at a schematic and figure it out, get real! You're no help at all!
Posted on Oct 05, 2010
  • David Higdon Jun 06, 2013
    saved my confused self !! thought there was a special tool for the band or something , thank you !!!
4 Suggested Answers
SOURCE: chain saw wiil not stop chain in ideal how do you adjust brake
clean the clutch bell out with a air compressor or somthing
Posted on May 29, 2009
  • 583 Answers
SOURCE: poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Posted on Jul 25, 2009
  • 2239 Answers
SOURCE: Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Posted on Aug 23, 2011
Testimonial: "Thankyou very much !!"
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need to have a manual on this wild thing so that i know the right ratios for the gas.
This Chain Saw requires a 40:1 gasoline to oil mixture. This is typical for all 2-cycle motors. More information can be found here:
http://www.ehow.com/how_4464807_fuel-poulan-wild-thing-chain.html
Aug 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
No problem i want to know how big the motor is in cc's
40 CC's or 2.5 Cubic inches
Poulan, Wild Thing, 2375, 18" Gas Chain Saw, 2.5 CUIN, 40CC, 2 Cycle Engine, Vertical Cylinder Design, Dual Counterweight Crankshaft, Primer Bulb, Inertia Chain Brake, SuperClean Air Filtration System, Gear-Driven Automatic Chain Oiler, Full-Wrap Handle
Mar 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I just took apart the brake mechanism on my poulin
The only known illustration for a Poulan 2375LE is here:
Poulan.com
It appears they want you to purchase the entire clutch cover. There is no specific detail.
Type 1 pn530054740 item 39 $19.43
Type 2 pn545139903 item 36 $19.43
There are other than 2375 Wild Things.
Go here for additional help identifying your saw. Please have it within easy reach if telephoning.
http://www.ordertree.com/cms/Contact+Us/6.html
HTH
Lou
Oct 17, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing chain saw rope came off
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
344 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
