Question about Volfenhag ZX-8400 Car Audio Amplifier
I have a volfenhag zx-8400 and it just geos into protection mode
It is wired fine and when i turn on my deck, it goes right into protection mode and you can hrar my sub tick. I have two diamond audio d6 12s.
  • 58 Answers
The most likely problem would be a blown fuse. I would replace all of the fuses.
Posted on Oct 24, 2009
Amp turns on but no green light and no sound
As a pro i have ran into this problem many times,what happens with volfenhag amps the solders on the RCA inputs aren't very good,and what happens is that you get to much current going threw them and they over heat and lose contact,volfenhag will fix it,you have to pay for shipping to them,and include a 12 dollar money order.Volfenhag audio 1-323-588-8571.
Jun 03, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Protection mode keeps coming on
That probably means that it's getting a surge of power. Do you have a fuse from your battery wire to your amp? Check also your ground wire. You may need to upgrade your ground wire.
Mar 03, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
I have a volfenhag zx-8400 amp. i dont have a manual. whats the proper way of conecting amp? its mounted on my speaker box, which is ported, 12' volfenhag 2500 watts. on the side of amp it had voltage...
The voltage prolly says like 100Mv-2v, it doesn't really matter, just know that that the lower you turn it the harder it bangs. The X-over depends on where your box is tuned, crank the knob down too about 40htz and you'll prolly be good, just don't turn it lower than your box's tuned frequency. And your rca's go to line input. And there shouldn't be a problem with mounting your amp vertically, you prolly just had a bad connection. Hope this helps if you have more questions please ask...
Sep 21, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Is my amp or wiring bad? volfenhag zx-8400, 2000watts amp
Sounds strange,
Put a voltmeter on your car, to see if the voltage is stable when the engine is running.
if it is unstable, turn your car off immediately, to avoid damaging other electrical components.
If the voltage does not stay between 12.8 - 14,5volts (engine running) then the Rectifier is shot on your alternator.
Is your Amp screwed to the metal of the car? B'cos it shouldn't be.
if that doesnt help, try another RE-wire (you may have missed something) after refreshing your memory with an AMP wiring diagram.
Or just take it out & get it tested,
if its out of warrenty open & inspect the circuits for burns, a shop will charge just to look at it.
Sep 18, 2009 | Car Audio & Video
Sometimes my amp works sometimes it dont.
it could be your wiring or grounding to your amp, also check fuses on amp
Sep 16, 2009 | Car Audio & Video
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Protection Light coming on with loud volume and power
It's most likely that the over-current protection is tripping at high power. At lower voltage, the amplifier can't produce as much output power and therefore can't produce enough current to trip the protection circuit.
You need to check your speakers to make sure that they are not shorted. With an ohm meter, the resistance across the voice coil shouldn't read any less than ~90% of the rated impedance.
If the speakers and the wiring are OK, the amp may have an internal fault causing the amp to go into protection.
Let me know if you have any other questions.
Aug 13, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Volfenhag ZX-8400 Car Audio Amplifier Logo
260 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
