Washing machine won't go into a spin cycle.
I have a "Magtag Performa" washing machine. Model # PAV3240AWW. It will not go into a spin cycle. Agitate, water pump, work.
    President:
  • 1,922 Answers
Check the lid safety switch for proper operation
Posted on Oct 04, 2009
What year is Performa washer model PAVT910AWW
Please check this with the dealer or from the website.
Magtag performa
Jan 21, 2013 | Maytag Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Washing Machines
Magtag washer wont spin or drain, model #lat9806aae
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | Maytag Washing Machines
I have a maytag performa top loading washer, model # PAV3240AWW, that overflows. It doesn't happen every time and it doesn't matter what size the load is or what cycle I am using.
You have sand and sediment in the sump base of tub. All you di is remove the rubber hose on the water level switch and blow out the tube with your mouth. You will feel it when the **** is out of there. Then reconnect that hose tightly to the switch and pump out any remaining water in the tub. here are some repair photos
Oct 08, 2009 | Maytag Performa PAV3200
8-24-2009 5:55 P.M. I have a Maytag Performa PAV3240AWW top loading washer 2-3 years old has worked well for an active family of four until the last load of wash. It seemed to wash and rinse cycle OK when...
It sounds like the belt broke or the lid switch could be bad. Use a screw driver to manipulate the switch with the machine on. If you can tip the thing back enough to check the belt. I hope this helps.
Aug 24, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
My Washing Machine won't drain, the motor sounds but no spinning happens. Maytag Performa Model # PAV3240AWW
you have blocked filter or pump has an object in it if machine is about 2 to 3 years old pump may need replacing
Oct 19, 2008 | Maytag Washing Machines
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
WASHING MACHINE
There could be a couple of reasons for this. When this occurs, look to see if the load is evenly distributed around the circumference of the tub. If not, redistribute and continue with spin cycle. The machine may not be level. Check to ensure that the machine's leveling legs are making contact with the floor and that there is no movement when you attempt to rock the machine. If the unit is sitting on a soft floor, this could happen from time to time.
Jan 26, 2008 | Maytag Performa PAV3200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
