Question about Electronics - Others
Hi takero here having problem with my seagate freegagent 500gb. Would not connect for awhile and now it connects but when opened error window stop me from explore and is empty. Can it be repaired and recover all my files, photo's etc...
  • 23 Answers
Ya by downloading the disk repair software and you wil have the back up .................
Posted on Oct 06, 2009
Windows has stopped this device because it has reported problems. Code 43 This message pops up in when i plug in my SeaGate Free Agent GoFlex hard disk.
Try this as a possible fix.
This trick can quickly fix many mysterious hardware failures
The other thing I've heard of happening is a few of the USB 3.0 ports having problems with USB 2.0 equipment. I know it should be back compatible, but Windows can have problems. Try another USB port to see if that helps.
Does the SeaGate cable have 1 or 2 connections to the computer? Unfortunately, most external hard drives need to connect to 2 USB ports to get enough power.
I just looked up this problem on Seagate's website, and they pretty much come up with the same answers. Uninstall and re-install the USB drivers with the SeaGate connected. Or use other USB ports. The other suggestions they have don't make sense, if you can't talk to the thing, how do you run Seatools or checkdisk?
Fixya doesn't allow me to put in another link at this point, so you'll have to copy and drop this into your address bar.
http://knowledge.seagate.com/ka030000000tmkPAAQ
Here's another write-up on fixing the code 43, I wouldn't do number 6.Update BIOS though, USB is working fine with everything else, it's NOT the BIOS that's having a problem.
http://pcsupport.about.com/od/errorc/a/code-43-error.htm
Jul 26, 2016 | Seagate 500GB FreeAgent GoFlex Hard Drive
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a seagate freeagent go 500 GB drive. It fallen on ground (from one Ft. height). when i connected it now it's light is flashing continously and it's not recognized by system. upon connecting...
Hi'' so sorry for you , yes hard disk are so delicate when it fall , a fragile hardware even with just a little bang on tables or to a hard things the next is it would be damage , so here is another way to check on how to see back your files on the 500gb HHD you dropped,i hope this can help you, Open and connect to an unplug pc, if your 500gb HDD is a sata connection use the sata wire to connect hard disk directly to a PC mother board , insert the sata wire to a Sata port and put a supply on the disk , but be sure your disk is placed on top of box or books just to make sure it would not make any short circuits and then start power on, this is very risky work ,a professional technician is recommended to work it out .
Jul 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My HDD Seagate Momentus 5400.6 500GB is not recognized by win7. I have connected it like a ex USD HDD, but there is no USB devices in Device manager. The hdd is clicking -1sec click, 0,5sec off. Thanks,...
Hi, it might be a file system error.
You could try removing the hdd from the usb enclosure and connect it directly to your pc via SATA.
(power off both of them before doing so)
If it really is the file system then scan disk should repair it automatically when turning on the pc.
Then if the pc recognizes it you can put it back in the usb enclosure.
Jun 30, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
When I try to format my seagate expansion portable drive 500GB the error message appeared is : windows was unable to complete the format. Is there any solution to this problem?
If you are connecting this drive to your machine with firewire while you are trying to format it try connecting it to your machine with USB. If it formats okay that way you can connect it to your machine with firewire again after the formatting is complete.
Also make sure you have set the formatting process for the correct file system. For example FAT32 or NTFS.
Also, you did not mention which operating system you are using. For example a computer running Windows Millenium will not format many of these drives at all.
HTH
Jun 12, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
Since I connected a Seagate Replica 500GB Hard Drive, I started receiving multiple Error 51 Events in my Windows Event log. They state: An error was detected on device \Device\Harddisk2\DR9 during a paging...
First, extract all data that you have on the hard-drive, while you still can.
Seagate's web-site suggests that you first download and run Seagate's "Drive Fitness Tool", which exercises the disk-drive, and produces a "fitness" report. If it fails, then delete all your "private" files, and either take the drive back to the retail location where you bought it, or get an RMA (Return Materials Authorization) from Seagate, to get permission from Seagate to return the drive to them, for them to analyze the disk, and probably replace it.
Sep 28, 2010 | Seagate 500GB REPLICA USB 20 16MB 25IN...
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Electronics - Others Logo
29 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
