Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Is there a cold water filter on this machine. The
Is there a cold water filter on this machine. The cold water is coming in very slow compared to the hot water and is getting stuck on the rinse cycle. Any suggestions!! Thanks
  • 736 Answers
There is often a screen located in the hose end ... you can clean, replace or remove the screen and always replace the hose washers but its far better to replace both hoses with good quality new ones .. the safe lifetime of the hoses is only a few years ... so its a good idea to replace them every few years anyhow ... while you have the hoses off you can check water flow to make sure the shut off valves are not clogged .. (make sure they were both fully "on" to start with) .. if there is good water flow and the screens are not clogged then you may have a clogged solonoid valve (just inside the machine at the water inlets) (has wires going to it also)
Posted on Oct 04, 2009
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
Cold water flow seems blocked. It comes out very slow.
in the inlet pipe is filter ,remove the water inlet pipe and have a look should be thumb size filter that comes out for cleaning
Dec 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Cold water filling of tub is extremely slow. No kinks
turn cold water off and remove hose from washer,next remove the screen from the water inlet and clean it and place it back in the valve, place hose back on the inlet,turn cold water back on and test cold setting,you should have good flow.
Dec 25, 2009 | Roper RTW4300SQ Top Load Washer
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Slow cold water fill, now no rinse/spray cycle
There is a filter screen inside the cold water valve.
Remove the hose, then take the filter screen out and clean it.
Replace it in the valve.
Problem solved until it stops up again.
Mar 12, 2009 | Washing Machines
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Not working
Disconnect water hoses from machine. Inspect the filter screen on the cold and hot water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove debris or water flow is still slow, replace valve.
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Maytag Atlantis MAV9501E Top Load Washer
Very little cold water comes in th washer
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Jun 26, 2008 | Dryers
Kenmore washer
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve. As far as the spin is concerned, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin.
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
