Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
How do I get to the lamp?
I have removed the back panel .Where is the lamp located?
  • 87 Answers
Lamp is accessed from front. loosen 2 thumbscrews on bootom back and pull. Sounds like its breaking plastic the first time
Posted on Dec 23, 2007
Lamp changing Instructions for tv model wd-52525
Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
Mar 18, 2011 | Mitsubishi Televison & Video
Need to replace rear brake light just pull hard and the bulb will come out of the hole
Please don't forget to rate! Thanks!
  1. Disconnect the negative battery cable.
  2. Remove wing-nuts attaching tail lamp to rear closure panel.
  3. Remove lamp from opening in quarter panel.
  4. Disconnect wire connector from back of tail lamp.
  5. Remove tail lamp from vehicle.
  6. To install, reverse removal procedure.
Locating wing nuts (2) in the trunk (1)
Removing taillight (1) and connector (2)
Identifying taillight components
Jan 22, 2011 | 2000 Plymouth Breeze
Replace a brake light
COUPE The side marker lights for the SC and SC2 are part of the turn signal/parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. Rear Turn Signal, Brake and Parking Lights EXCEPT WAGON
  1. Disconnect the negative battery cable. Fig. 5: Remove the trim panel fasteners - except wagon 84196109.jpg
    Fig. 6: Carefully remove the trim panel - except wagon 84196110.jpg
    Fig. 7: Pull the lamp assembly straight back and out of the opening 84196111.jpg
  2. Remove the trim panel fasteners, then carefully remove the trim panel.
  3. Remove the 2 retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  4. Tilt the assembly downward for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  5. Installation is the reverse of removal. Fig. 8: Tilt the assembly downward for access to the sockets 84196112.jpg
    Fig. 9: Twist and remove the socket and bulb from the lamp assembly 84196113.jpg
WAGON
  2. Remove the retaining screws from the side of the lamp assembly, then pull the lamp assembly straight back and out of the opening.
  3. Tilt the assembly for access to the sockets, then twist and remove the socket(s) from the lamp assembly. Replace the bulb(s), as necessary.
  4. Installation is the reverse of removal. Fig. 10: Exploded view of the tail lamp assembly - wagon 84196114.gif
High-Mount Brake Light EXCEPT WAGON
  2. Open the trunk for access to the lamps.
  3. Locate the bulbs at the rear underside of the trunk lid. Remove the bulb(s) by twisting, then pulling straight out.
  4. Installation is the reverse of the removal. Fig. 11: Remove the high-mount brake light by twisting its socket 1?4 turn counterclockwise - except wagon 84196115.jpg
WAGON
  2. Raise the liftgate, then remove the wedge blocks from each side of the liftgate assembly.
  3. Remove the lower fasteners from the liftgate lower trim panel, by pushing in the center of each pin approximately 1?8 in. until it clicks, then remove the fastener.
  4. Insert a screwdriver or small prybar into the hole in the lower trim panel (located near the wiper pivot on the pivot hump) so that the tool sits on top of the pivot. Lift up on the tool handle to disengage the trim panel upper clips, then remove the lower trim panel from the vehicle.
  5. Unplug the high-mount brake light wiring harness.
  6. Remove the brake light fasteners, then remove the lamp assembly from the liftgate.
  7. To remove the bulb(s), push slightly on the top edge of the lens and rotate it away from the housing. Remove the bulb(s) from the housing. To install:
  8. In order to prevent the possibility of water leaks into the liftgate, inspect the lamp gasket for damage and replace, if necessary.
  9. If removed, install the bulb(s) by inserting the bottom edge of the lens into the housing and snapping it into place.
  10. Position the lamp into the liftgate and tighten the fasteners to 35 inch lbs. (4 Nm).
  11. Connect the wiring harness to the lamp assembly.
  12. Align the upper clips on the lower trim panel to the liftgate slots, then install the panel by pushing at the clip locations.
  13. Reset the trim panel push-in fasteners by spreading the center pin tabs and moving the pin so that it sits approximately 1?4 in. out of the fastener. Insert the fasteners into the bottom of the trim panel and push the center pin until flush.
  14. Install the liftgate wedge blocks.
  15. Connect the negative battery cable and check for proper lamp operation. Fig. 12: Removing the liftgate lower trim panel assembly - wagon 84196116.gif
    Fig. 13: Exploded view of the high-mount brake light bulb and lens assembly - wagon 84196117.gif
Nov 04, 2010 | 1998 Saturn SL
I need to replace rear tail light bulbs on 1996 Saturn SL1
WAGON
WAGON
Reverse Light EXCEPT 1991-96 COUPE For the Saturn wagons and sedans, the reverse lamp is part of the rear turn signal, brake and parking light assembly. Refer to the procedure in this section for lamp removal and bulb replacement. 1991-96 COUPE
  2. Reach behind the bumper bar and disconnect the harness and socket from the reverse lamp. Remove the bulb from the socket.
  3. If necessary, unfasten the retaining nuts and remove the lamp from the bumper bar.
  4. Installation is the reverse of the removal. Fig. 14: Exploded view of the reverse lamp mounting - 1991-96 coupe 84196118.gif
Oct 23, 2010 | 1996 Saturn SL
How to remove lamp of epson projector emp-82
the top of the projector back left hand corner facing the lens. there is a panel door there is a screw located on the rear of the unit that holds the lamp cover. remove this screw then slide and lift up on the panel door. As you look inside you will see two lamp screw that need to be removed as well. hold the lamp and lift it up out of the projector. Insert the new lamp and replace the screw.
You will then need to reset the lamp hours in configuration menu. This is a good time to clean your filter this is located on the bottom of the projector near the front.
Jun 08, 2010 | Epson EMP-82 LCD Projector
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Wheres is the lamp located on the sony wega 50 inch tv
remove the two small covers left and right behind the front lower panel.remove front lower panel (its a firm fit) pull in this sequence 1 rht top, 2 left top, 3&4 lower mid. lamp behind a panel just to the left of cantre, remove two screws locating it in place .pull lamp housing out
Sep 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Where to locate the lamp assembly
Look at the TV from the front, on the stand just under the TV there is a panel. Reach around the ends of the panel and you will feel the fasteners that hold the panel on. Unscrew the fasteners and the front panel comes off and you will see the lamp in the front center.
Sep 20, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi WD-52525 Lamp
What is wrong with set? Is picture too dark? Or is Lamp completely out?
Nov 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
