Question about Car Audio & Video
Can not get am or fm in clearly? - Car Audio & Video
  • 128 Answers
You may have to remove the radio and check to make sure the ant. is still plugged in on the back
Posted on Oct 04, 2009
My tao xm2go unit is transmitting a very weak fm signal to my car radio. I can barely hear the audio.
You likely need to directly connect. In most cases the FM transmitter is too week to broadcast through FM stations, and a direct connection will clear up your issue. It could be as simple as connecting via an Auxiliary cable or Cassette Adapter. If you don't have the ability to use one of those, you can get an Auxiliary Input Adapter. Another solution would be an external FM Transmitter, with a larger range.
Jun 26, 2012 | Tao XM2go Satellite Radio Receiver
The AM/FM on my 1999 Electraglide has a reception problem that just started. FM stations that used to come in loud and clear don't come in at all when the ignition is in the "on" position. They...
Charging system, ignition system, or battery is starting to feed noise through the ground of the radio. Check all the bikes main grounding points and make sure they are secure and making positive contact.
Jan 10, 2011 | Harley Davidson 426290 AM/FM Radio
Not clear on how to search and store radio frequencies manually in my Kenwood kdc-bt6544u car audio player. can i jump to a specific time in audio or do i have to hold the FF or RW till i get there? not...
Some makers are different.Usually if you hold down the search button long enough,it will switch to autosearch.There should be numbered buttons on the face of the stereo too right?Tune in to the channel you want to preset,press and hold down the number you want it to be.The sound will probably cut out for a couple of seconds,then when it comes back on the channel is preset.Once you set 6 on FM,if you press the band button again,it should give you the capability of presetting 6 more.If it goes to AM just press band once more and it will give you 6 new FM.Usually current radios give 6 AM possible,and 3 separate bands of FM for a total of 18 FM possible.Good luck! Greg
Aug 16, 2010 | Kenwood Car Audio & Video
2007 Camry: I can't receive clear radio channel in camry 2007 ...
if you have a factory radio, then chance are you antenna is amplified (even if you don't have an antenna that goes up in the back). The fuse for the antenna amplifier could have blown or the amplifier itself my have gone bad. It could also be your radio but, i would check those things first... Just a side note: i don't know of any stations that around me that aren't odd numbers 92.3 fm,95.5 fm,100.3 fm. Where you able to tune it to 100 fm before?
Apr 28, 2010 | Cars & Trucks
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
No fm reception
We had trouble switching from AM to FM. We finally solved the problem by pushing the reset button on the back of the unit (any sharp pointed object can be used to engage the reset button). Do this followed by setting the mode to FM and try tuning in your FM stations. Try the procedure several times and it may finally kick in, as was the case with us getting our AM stations
Dec 30, 2007 | GPX HM3817DT Shelf System
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
