Question about The Times Case Corporation Tractors International Harvestor
Versatile 555, was working fine, while pulling drills,i stoped and took the tractor out of gear, left running i got off the tractor for 10 min, returning i put the tractor in gear and it would not move,? the pump drive key has been checked and is ok, fluid level is ok, clutch pressure light stays on.
Versatile tractor
If you are trying to find the Versatile Tractor Company...
http://www.versatile-ag.ca/NA/EN/index.php
Mailing Address
1260 Clarence Avenue
Winnipeg, Manitoba
Canada R3T 1T2
Phone/Fax
Ph.: 204.661.8711
Toll Free: 888.524.1003
Fax: 204.654.2503
Email
info@versatile-ag.com
Jul 07, 2014 | Computers & Internet
Gta4 cheat codes ps3
Enter one of the following codes during game play. A small box will appear to confirm correct code entry.
Code: Result:
Circle, X, Circle, Square, Triangle, L1, R1, L2, R2. Any truck with trailer
R1, L2, R2, L1, Up, Down, Up, Down, Up, Down. Cop
Triangle, Left, Right, Circle, X, Up, Down. Drink beer
R1(2), L1, R2, Triangle, Left, Right, Square. Fly in the air
R1, L1, L2, Square, R2, Left, Right, Left, Right. Health
X, Circle, Circle, R1, Square, L1, Triangle. Helicopter
Up, Down, L2, R1, X, L1(2), Right, Left, Up. Listen to Back On My Grizzy in car
R2(2), Up, Circle, L1, L2, Down, Triangle, R1, Right(2). Listen to Crank That SouljaBoy in car
Circle, Right, Circle, Right, Left, Square, Triangle, Up. Lock wanted level
Up, Down, L1, L2, Left, Right, R1, R2, Square. Money
L1, Circle, X, R1, L2, R2, Square, Triangle, Triangle, X. Monster Truck
R1, Circle(2), L2, R2, Triangle, X, L1, Right. Never die
Press X, Circle, Triangle, Up, Down, Left, Right, Circle(2) while in an area with a lot of space. Private jet with pilot
R1(2), Left, Right, L2, Square, Triangle, L1, Circle. Run quickly
L1, R1, X, Circle, Triangle, X, R1, Square. Semi truck with trailer
R1, Circle, L1, X, Left, Down, L2, Up. Smoke
Up, Down, Left, Right, Circle(2), Left, Right. Tank
Square, Circle, X(3), Triangle, Square, Circle(3). Unlimited bullets
Square, Left, R2, Down(2), L1, Up, Circle. Unlimited money
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up, Right(2) Weapon tier 3
R1, L2, R2, L1, Up, Down, Left, Right, Up. Weapons tier 1
R1, L2, R2, L1, Right, Down, Left, Up, Right, Down, Left, Up. Weapons tier 2
Cell Phone Passwords
At any time during the game, pull out Niko's phone and dial these numbers for the desired effect.
Password: Result:
468-555-0100 Change weather
486-555-0150 Get a different selection of weapons
486-555-0100 Get a selection of weapons
267-555-0150 Raise wanted level
267-555-0100 Remove wanted level
362-555-0100 Restore armour
482-555-0100 Restore health
227-555-0142 Spawn a Cognoscenti
227-555-0175 Spawn a Comet
938-555-0100 Spawn a Jetmax
625-555-0150 Spawn a Sanchez
227-555-0168 Spawn a SuperGT
227-555-0147 Spawn a Turismo
359-555-0100 Spawn an Annihiliator
227-555-0100 Spawn an FIB Buffalo
625-555-0100 Spawn an NRG-900
Jun 04, 2014 | Video Game Consoles & Games
Ducati 748 runs then stopes
check the coils. coils on their way out will work fine until warm then get too weak to fire. Does it run fine all the way to the shut-off point or des it cut out or begin to misfire?
Apr 12, 2014 | 2000 Ducati 748 E- S (Biposto-Monoposto) -...
Starts but shuts off after 10-15 min
Yes that is a shut off valve and im thinking either its a lose wire or it needs to be replace
Oct 03, 2012 | Craftsman 18.5 HP 42"
Transmission in 2002 cadillac deville stoped working after 20 min drive i shut car off and restarted and it worked
Get your Automatic Transmission Fluid (ATF) checked, it could be old or low. May be time for Transmission flush, too.
GL,
Td
Oct 03, 2012 | Cars & Trucks
HOW DO YOU PULL THE CHUCK OFF TO GET TO THE GEARS INSIDE SEEMS TO BE STRIPPED OUT WANT TO TRY AND REBUILD MYSELF ITS A DW995 TYPE 4 MOTOR RUNS FINE JUST WANT GRAB.
if its a reversible drill,you open the jaws wide,and undo the left hand threaded screw inside the chuck,then put the the chuck tool in,and use that to unscrew chuck off the thread,right hand thread
Jun 29, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Replaced motor,car run fine.Lost transmission fluid replaced it with to much fluid.Took it for a drive woked fine & shifed as it should,stoped at a stop sign went to pull away and had no gears.There...
Sometimes the axel shaft backs out of the transmission on front wheel drives when not seated correctly. This usually occures in new transmission or engine swaps. I would take a look at the driver side shaft for fluid residue and shaft placement.
Oct 24, 2009 | Toyota Camry Cars & Trucks
Transaxle locked in gear won't roll freely in neutral
Sounds like the pins in your brake caliper have gotten dirty and/or rusty and are not releasing all the way. When I had my shop, we found a lot of these and I or my mechanics pulled and cleaned them then took a drill 1/64th larger than the pin and ran it through the holes in the caliper, NO MORE PROBLEMS!
Check your tire pressures, too, if they are low it will be difficult to roll.
Sep 14, 2009 | Garden
The Times Case Corporation Tractors International Harvestor Logo
260 people viewed this question
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
