Question about HP Pavilion dv9000z Notebook
Can I set up for both DSL and dial up reception?
Can I set up my laptop for both DSL (winter home) and dial up (summer home). We go back and forth
several times during the summer months and I'm wanting to avoid a
re-install every trip if there is a way to accomplish this.
    Sergeant:
  • 195 Answers
Yes you can...
Posted on Oct 05, 2009
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
I just had a representative from the Geek Squad set up my Epson WorkForce 633 Fax/Printer/Copier. The time that we set up is not what I wanted. I want a 12 hour set up, and I need to reset the clock on...
Below you will find the instructions straight out of the manual. I have also put a link to the whole searchable HTML manual at the bottom of this post Enter the Date and Time Before setting the date and time, you should select the appropriate Daylight Saving Time setting for your region. This setting lets you easily set the clock one hour ahead or one hour back when the time change takes place. 1. Press the fax.6.7.1.jpg Setup button. 2. Select Printer Setup. You see this screen: fax.6.7.2.jpg 3. Select Daylight Saving Time. 4. Select Summer if your region uses Daylight Saving Time and it's currently in effect. (DST is effective from spring through summer.) Otherwise select Winter to turn off the setting. Note:
When you change the setting from Winter to Summer, the clock is automatically set ahead by one hour. When you change it from Summer to Winter, the clock is set back. The setting is not automatic; you need to change it each season. 5. Select Date/Time. You see this screen: fax.6.7.3.jpg 6. Select the date format. You see this screen: fax.6.7.4.jpg 7. Use the numeric keypad to change the date, then press OK. fax.6.7.5.jpg 8. Select the time format. fax.6.7.6.jpg 9. Use the numeric keypad to change the time, then press OK. 10. Press fax.6.7.7.jpg Back until you return to the home screen. Epson Work Force 633 Manual Hope this helps. Zeppelinx12
Mar 10, 2011 | Office Equipment & Supplies
I touched thrmostat to change setting when it was shocked by a carpet shock. what do i do? thanks rick
If it was just a static electricity carpet shock, raising the humidity level in your home will reduce that problem. In the winter, the interior air of the home becomes to dry. 30 to 40% humidity is about what you should try to maintain in the winter. 0% or as close as you can get to it, in the Summer.
Feb 22, 2011 | Heating & Cooling
I got a used laptop I was told to clear it and than dowload windows xp back on it I have wireless at work but home I have dail-up and it tells me I have no modem help
Dial up connection needs a modem for the authentication with a telephone number - without modem no one can work with internet .yes if you want to use your laptop wireless you can do it but to do that you should have a DSL service with a wireless router .
this is how the connections in DSL is been done
DSL(telephone line) ->modem->wireless router->computer
Oct 05, 2010 | Computers & Internet
How do you set the temperature of the freezer...my freezer freezes at the mid setting on the control dial.
get a thermometer and set the freezer to -18C and a fridge to +5C.
these are the optimum temperatures for keeping food.the internal knobs are for guidance once set,to adjust to seasonal changes.summer to winter.....and for when you refill
Aug 28, 2010 | Magic Chef MCBR440 Compact Refrigerator
Setting
4 in winter 5 in summer depending on how often the door is opened per day i would set it at 5 all yr round
Jul 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
What motor oil weight should I be using on my 96 olds 88....we live where the winter temps can go as low as -10 F and as hot as 95F in the summer
5w 30 or 10w 30 during the winter. After an oil change... check your oil after 200-300 miles of use. Is the level the same? If so your weight is fine. If it drops, it's to light of an oil and your engine is now "drinking it" like fuel, move to a heavier weight. As far as Changing between winter and summer. Changing Oil weights is not bad for your motor so if the winter you go with 5w 30 and it works, great, shoot for the same during the summer. If it seems to "drink it" during the summer using this weight, go up to the next (10w 30)
That being said. Changing from natural oil, to synthetic, back to naturual , or vice versa... swapping back and forth between these KINDS of oil has been known to cause damage. so whatever weight you decide on, stick with one "type", natural or synthetic.
Feb 27, 2010 | 1998 Oldsmobile 88
Frs23h5asb6 is freezing food on refrigerator side. Turned refigerator control off, still is 33.5 deg. Took out all bags to increase air flow. Is thermostat bad?
first of all are you talking about summer or winter, i dont know what state you live in. the weather and humidity play a big part on your unit,is your kitchen as warm as in is is winter,if not turn down the freezer control down ,turn on refrigator control 1/4 of the way.until you get both sides of the unit working at the right temperatue.you may have to adjust the settings a few times.using the freezer and refrigerator controls back and forth. also in the summer you can usually back down the controls to adjust in the temperatue change. no more frozen lettuce in your fridge,i hope.,,,,,,,,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Connection via DSL works. A laptop attempting wireless does not
Check the ssid settings in your router to make sure it is being broadcast
Jun 07, 2009 | Westell Wirespeed VersaLink...
HP Pavilion dv9000z Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
