Question about Whirlpool LER5636P Electric Dryer
Kenmore dryer takes a lonf time to dry
The dryer appears to be working fine, however it seems to take a long time to dry. The dryer does get pretty hot when it's on so it seems that the element is working.
    Problem Solver:
  • 14 Answers
Heat relay switch?
Posted on Dec 23, 2007
Kenmore elite dryer 4e just stopped working with no problems no power what so ever
Ok, try it on timed-dry.
Then pull the dryer out from the wall and take the vent hose OFF it in the back, and then try it on auto-dry with no clothes in it and see if it runs through fine.
or: Appliance Repair Forums
Oct 10, 2017 | Kenmore Dryers
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Dryer stops too soon
if the dryer seems to be running fine check the vent line and the duct that the lint filter slides into,most likely if it takes to long to dry clothes lint is blocking the air movement somewhere,when was the last time you cleaned out the dryer and vent line,you should clean the dryer once a year so you don't have a fire and your clothes will dry on time,if the vent line is long remove it from the back of the dryer and blow it out with a leaf blower,remove the lint filter duct and clean it and vac out the cabinet where the motor is.
Apr 23, 2013 | Kenmore 63942 Dryer
I have a dryer # 67832791 and doesn't seem like it heats up and takes longer to dry the clothes. Seems to run fine and operate fine just not drying the clothes.
restriction in the venting, disconnect vent tube, leave disconnected dry clothes and if they dry then clean out vent tube(vacuum, leaf blower, etc). Hope this helped Tim
Nov 28, 2010 | Kenmore Dryers
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Whirlpool LER5636P Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
