Question about Dryers
Wired 3 prong power cord as directed in the owners manual and the dryer shocks me. if i try to put the flex tube exhaust on it sparks
  • Dryers Master
  • 8,404 Answers
Check the polarity of your outlet. Make sure you have the neutral where it goes and of course the two legs where they go and that follows through to the drier. If this continues, you may want to get a licensed electrician to complete this project.
Posted on Oct 04, 2009
  • 557 Answers
You have one of the hot legs hooked to ground. Each leg should be 110. Get a meter and check your recepticle maybe someone wired it wrong. L1=110 L2=110 & a ground (green wire)
(spade) (spade) (round or D shape)
How do I change a 4 prong to a 3 prong dryer code
When replacing a 4 prong cord with a 3 prong cord you put black and red wires to the outside posts of your terminal block. The white wire from your three prong dryer cord goes to the center of your terminal block. The yellow and green wire from the dryer go together and attach to the cabinet ground.
Nov 22, 2014 | Dryers
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Went from a 4 prong to a 3 and get shocked sometimes.
You need a meter. Unplug the dryer and check for continuity between either of the 2 hot legs and the frame.
Sep 04, 2012 | Kenmore 62602 Electric Dryer
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Trying to make a 3 prong power cord a 4 prong power cord need to look at manual for it says to see manual and i do not have one
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 14, 2010 | Dryers
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
4 prong to 3 prong
Get the 4 prong cord off. Put the 3 prong cord on.
The middle wire(neutral) on the middle post. The other 2 wires are hot wires. Make sure you have the middle wire in the middle and a wire on each side if it. The Green wire is redundant and NA on 3 wire receptacles. Directions should be posted just above the terminal block.
Dec 14, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I am trying to change the dryer cord from 3 wire and 3 prong wire to 4 wire/prong wire. I have put the white wire in the middle and black and red on the sides. But the dryer already has a green wire fixed...
If this is for US Standard wring, plese click on the following link for a full explanation of how to convert from a 3-prong to 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have any questions after reading through the link, please let me know. I hope this answers your question(s).
Jul 26, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
