Question about Garden
Poulan pro 6.5 21'' lawnmower will not run. after primming 3x's, the mower will begin to run, then just shut off. how do I get to the fuel filter and carbarater?
    Novelist:
  • 168 Answers
Sounds like the center bowl nut is restricted. Remove it with either an 1/2 in or 9/16th box inch wrench and clean out all the holes with a small wire. Reinstall it and then give it a try. If that doesn't work then you'll have to remove the carburetor for a complete over haul. Take special note as to how the governor rod is connected before removing. If you have a digital camera take a picture of it, so you can refer to it in the event you can't remember how it goes back on. It probably doesn't have a fuel filter so it does become very subjected to dirt from the tank. The only filter you have there is manufactured in the tank outlet. some Tecumseh models just have a nipple and no filter built in them with a straight hose coming off the tank directly to the carburetor. Good luck
Posted on Oct 09, 2009
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
Where is fuel filter
You will rarely if ever have a fuel filter on a push lawnmower. It may be that because of the fact that fuel consumption is very low, a filter would not be easy to incorporate into the system. Consider being sure that you start each season with fresh fuel and you should not encounter any problems. Leaving old fuel in a tank at the end of the season can prove to be very damaging and troublesome.
Jun 29, 2014 | Poulan Pro 22" Self Propelled High Wheel...
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
I have a Poulan 450 push lawnmower, and it's only a month old, and I've only used it once before to cut my yard. It worked perfectly, and now three weeks later I added gas to the mower, and the oil level...
Remove spark plug,it may be fouled and have gas on it,clean it and then reinstall and try if that doesn't work,try a new one.Also check the air filter,may need cleaned or replaced.
Jul 09, 2017 | Poulan "" Push Mower
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Jul 09, 2009 | Garden
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Garden Logo
300 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
