Replacing thermal coupling - Heating & Cooling
  • Ned C Cook
    Ned C Cook May 11, 2010
    Thermocoupler on an A/C unit?
  • Ned C Cook
    Please elaborate
  • 34 Answers
Very hard to explain without seeing unit. easiest way is to by thermocouple first so you know what it looks like and they generally come with instructions. It will be located in direct path of pilot light. its function is to tell the main gas valve is ok to open because pilot light is on as a general rule they are not hard to replace but i do recommend buying one by unit model number b4 trying to take out the old
Posted on Oct 10, 2009
Pilot goes out might stay on for a week or a minute
pilot fault not giving enough power to thermal couple or replace thermal couple
Apr 20, 2014 | Bosch & Tankless LP Hot Water Heater
Whirlpool duet dryer model WED8300SW0. dryer would not start replaced Thermal fuse. Worked a couple of cycles then won't start again. Replaced thermal fuse and thermister worked a couple of cycles then...
The thermal fuse is a safety so if you have an obstruction in vent line from the back of dryer to the outside the fuse will continue to blow until the airflow obstruction is cleared.
Mar 05, 2014 | Dryers
How do i replace dc17 thermal switch. i have
I don't believe there is an external thermal reset. It is most likely built into the motor.
Oct 22, 2013 | Dyson Vacuums
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
Why cigarette lighter does not work?
80 Series cig lighters have a fuse and a thermal couple, as do most cig lighters. The fuse will blow if too much current is drawn but if an acceptable but high current is drawn for a long period the thermal couple may blow.
Note: the thermal couple can not be replaced like a fuse.
Dec 16, 2010 | 1991 Toyota Land Cruiser
Pilot light is not staying lit. woke up to cold water.cleaned flame sensor. still no luck. any ideas?
sounds like a bad thermal coupling! if the coupling goes bad it will shut gas supply off as a safety precaution. it acts similar to a thermometer, if its bad then you will not get any gas through. it is screwed into gas valve and shuts the gas off. have a good day!! replace thermal coupling!
Nov 30, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Burner does not stay on .replace the gas control thermostat
it may be the thermal coupling. because if its bad it will shut the gas off. if the coupling gets hot on the end, it will turn gas on. it has to be in pilot light flame, to turn gas on. change thermal coupling. good luck !!
Nov 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Oven does not work but ignition continuously clicking
The thermal couple on the gas valve is not working, if this oven is old the thermal couple can be replaced independantly of the gas valve,
if is's newer the whole valve assembly must be replaced. if you have never worked on gas appliances call a pro by the way the valves run about $125.00 you might want to consider replacing the appliance
Nov 14, 2009 | Ovens
I replace my thermal coupling. burner doesn't ignite
is the burner assembly sitting pronperly on it;s cradle,, this will put it at just the right distance for it to ignite,,
Jun 15, 2009 | RTO Atwood Water Heater - 6 Gal LP
My laptop keeps shutting off
is the cpu fan running? if its on, then goes off, there is a thermal problem. check for vent blockage. keep it on a hard surface with air vents clear.
Dec 18, 2008 | HP Compaq Presario V2000 Notebook
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
