Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Oil drain plug? 08 fat boy cant find plug - Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
  • 116 Answers
Bottom of trans pan 2 plugs one oil other trans oil should be on bottomfront of pan facing forward rather than strait down by the way heres the best advice youll ever get from a websight buy a book
Posted on Dec 30, 2009
Where is the oil drain plug for a 2000 harley fat boy
Hi Anonymous, drain plug is in the bottom of the frame, right side, all the way to the rear. Good luck
Feb 02, 2014 | 2000 Harley Davidson FLSTF Fat boy
Where is the transmission fill tube for an '02 fat boy?
Top right side just below yer engine oil reservoir but above the frame rail about 10". An allen head plug, approx. 5/16ths faces up & forward @ about a 45 degree angle (it's your dip stick too) Takes about 1 qt. ??? Q is...how do you DRAIN it ???
Apr 13, 2013 | 2003 Harley Davidson FLSTF Fat boy
2005 fat boy oil change
Stand the bike upright. Remove the dipstick from the oil tank. Remove the drain plug on the bottom right side of the frame. While the oil is draining, replace the oring on the drain plug. Remove and replace the oil filter, after filling the new filter half full of oil. Replace the drain plug. Put 3 quarts of oil in the oil tank. Replace the dipstick. Start the bike and check for leaks. No leaks, you're done! I use HD Syn 3 synthetic oil in my '04 Fatboy, but you can also use a conventional 20w50, as long as it's made for use in and air cooled motorcycle. Don't use car oil!
Nov 04, 2012 | 2003 Harley Davidson FLSTF Fat boy
Wheres the drain plug on 2011 fat boy
theres 3 which one? Primary left side of bike bottom of inner primary just below derby over, transmission under bike between rear shocks , oil is right side bottom in frame just in front of pivot shafts . 5/8th plug
Apr 14, 2012 | 2011 Harley Davidson FLSTFB Fat Boy Lo
Where is the oil plug to drain the oil on a 2005 Fat Boy Harley Davidson
The oil drain hose comes of the lower back side of the oil tank on the right side of the bike. It runs down behind the transmission and comes out just in front of the swingarm down low on the frame. It either dead ends there with a plug in the end or it connects to a crossmember of the frame that runs underneath the transmission. If it connects to this crossmember, the drain plug is on the bottom side of the crossmember directly opposite the hose.
Good luck
Steve
Jun 04, 2011 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
I am switching from syn oil to reg hd oil on a 1992 flstf. Do I need to drain the engine case? If so, where is the plug located? Is there anything else I need to be aware of? THANKS
I would purchase a Harley Davidson repair manual or get one on CD from ebay not as much as a paperback and just as good. The repair manual is a mechanics best friend. Remember buy one it is the best friend you can have when doing maintenance on you harley.
The drain plug can be hard to find. In the 2001 Fat Boy, it is in front of the back motorcycle tire between the Fat Boy's rear shocks.
To do the oil change you need to warm up the oil so it drains better.
Tilt the motorcycle to its right side and position your oil catchment container under the oil plug.
Use your wrench set to unscrew the oil drain plug. In a 2001 Harley Davidson Fat Boy, you need a wrench that will fit a 1/4-inch screw.
Drain the oil. While oil is draining from your Harley Davidson, use the time to clean out the magnet and rubber ring positioned under the oil drain plug.
Remove and replace the oil filter after the oil has drained. Refill with 3 to 4 quarts of engine oil. Replace all parts, including drain plug.
Remember the HD manual will tell you how to check the level of primary fluid needed. Each HD is different and needs different amounts.
You check your primary fluid level through the inspection cover, which is the oval cover in the middle of the primary cover. You'll need a T25 Torx wrench to remove the bolts. Have a new inspection cover gasket in case you need it.
Add the fluid through the inspection cover. You can use any kind of oil petroleum or synthetic as long as it does not contain friction modifiers.
replace the gasket on the inspection cover if needed. Tighten bolts finger tight; then tighten the bolts at 10 foot pounds. Start with the top bolt and then tighten the bottom bolt. The third bolt is the right one, and the left bolt is last.
Mar 02, 2011 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Can't find oil plug for 2003 fat boy
Look down at the bottom of the frame behind the exhaust pipes. There is a large hose that runs down that way with a plug in it. Harley moved the drain plug to a crossmember underneath the frame. The plug screws upwards into the crossmember.
Good Luck
Steve
Sep 12, 2010 | 2003 Harley Davidson FLSTF Fat boy
Cannot locate oil plug drain for my 2001 Fat Boy FLSTF
So I checked another Harley maintenance book of mine, and it says "On pre-2000 Softails, the drain is on the right side of the tranny near the dipstick. On the 2000 and later Softails, the drain is located on the bottom between the two shock absorbers. The drain plug on Dynas and FLs is located on the bottom of the transmission case next to the oil drain."
I got this from another site, I was going to say, it might not be on the bottom, but I found this, seems nobody can find it. Hope this helps.
Jun 26, 2010 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
Where is the drain for a 2003 harley fat boy
There should be a hose that come off one rear corner of the oil tank, it either goes straight down to the frame with a plug directly underneath (has oil o'ring #11105). It could also just be a line that is attached to the swing arm with a hose plug in it and a funny spring clamp holding the plug in the hose. I think 2003 is the first solution though.
Jul 01, 2009 | Harley Davidson Harley-Davidson Motorcycle...
How do I change the oil on a 2002 fat boy? Where is the drain plugs?
On the fatboy, the oil drain plug should be on the right side, just under the frame, directly below the oil tank. The primary drain is on the left side under the derby cover on the bottom. The tranny drain is on the bottom towards the rear pretty much centered.
And, as our darlin' little miss piglet said, a maual is worth the investment.
Jun 28, 2009 | 2003 Harley Davidson FLSTF Fat boy
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
