Question about Apex Digital Computers & Internet
Apex DT250 converter stuck in standby mode
My Apex DT250 converter will not switch from the standby to on mode. Using either the remote or the manual button on the front, the unit will emit a high pitch whine, but not switch to on.
I just had the same problem and replaced the popped capacitor and it works. I had to use a 470uf 35 because radio shack didnt have any 25's. It only cost $1.59 so i bought 3 just in case it happens again
Posted on Jan 30, 2010
  • chungy07 Nov 07, 2010
    Hi how do I know which 470uF capacitor is popped on my apex dt250?
    And how do I change it?
  • daniellouie1 May 14, 2011
    I agree. Box failed just a little past coverage period.
    I opened the box and noticed the cap on circuit board at C8 position was bulging. The C8 cap was green and other three were black. Perhaps intended supply of flawed cap to just fail at the time of warranty expiration? One black cap at position C15 was bulging. Good that caps were bulging and had not burst. (Think of a carbonated can drink in the freezer after one hour - about to or already popped.) Have the four caps ready - not all may need replacing. Use good quality Phillips screwdriver & use firm steady force - 5 to 6 cover screws and two recessed screws hold the cover down. 4 circuit board screw. Be careful when removing AC power and mini-plugs - easy to overlook release clips. Use low watt soldering pencil, not high watt gun.
    Problem Solver:
  • 6 Answers
Got the same problem the transformer indside the box is junk causing it to fail. PS. STAY AVAY FROM APEX
Posted on Oct 24, 2009
Open up the unit because the warranty is no longer valid i assume and check the capacitors on the power supply. i did this on mine and i found that one of the 470uF capacitors was popped you can probably fix it yourself for about 10 dollars. its cheaper than buying a new one and definitely cheaper than having it sent out to have it fixed.
Posted on Dec 28, 2009
@daniellouie1 had the right answer
___________________________________________
I opened the box and noticed the cap on circuit board at C8 position was bulging. The C8 cap was green and other three were black. Perhaps intended supply of flawed cap to just fail at the time of warranty expiration? One black cap at position C15 was bulging. Good that caps were bulging and had not burst. (Think of a carbonated can drink in the freezer after one hour - about to or already popped.) Have the four caps ready - not all may need replacing. Use good quality Phillips screwdriver & use firm steady force - 5 to 6 cover screws and two recessed screws hold the cover down. 4 circuit board screw. Be careful when removing ACpowerApex DT250 converter stuck in standby mode - icon1.png and mini-plugs - easy to overlook release clips. Use low watt soldering pencil, not high watt gun.
Posted on Feb 09, 2013
The problem wasn't really Apex. There was a flood of cheap, bad capacitors at the right time and the DT250 boxes got stung. I had four boxes and all four eventually failed a 470u cap on the power board. http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 04, 2012
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
How do i program a vibe unversial remote for apex digital converter box
Use the code search feature to find something that can handle some or all functions of your Apex STB. If a search through all codes contained in the Vibe remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 13, 2016 | Televison & Video
Apex at2002 tv stuck in standby mode
A universal remote control might not work with this set properly. You should try to buy its original one.
Jul 27, 2013 | Apex Digital Televison & Video
Apex DT250 wont turn from standby (red light) to On (green light)
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Sep 24, 2009 | Apex Digital HT-150 System
Need Universal code for RCA remote with Apex DT250 Digital Conver
Use cbl/sat button. Your remote might use more or less than 4 digits. Use 749 or 00749. It'll probably work. It worked for me.
Jul 30, 2009 | Televison & Video
Need a Philips universal remote code for Apex digital tv convertr
try going to this Philips site and using their universal remote control finder tool ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20100815184715_64.252.199.203&grp=SOUND_AND_VISION_GR&ctn=SRP4004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
Feb 20, 2009 | Televison & Video
Computers & Internet Logo
1,516 people viewed this question
Top Apex Digital Computers & Internet Experts
David Payne
David Payne
Are you an Apex Digital Computer and Internet Expert? Answer questions, earn points and help others
