Question about Streamlight Sl 20 Xp Led Rechargeable Flashlight Full Size
Dropped mag light sl20 and it no longer works. Will not light up the led when I place it into the charger either.Could it be the bulb?If it is the bulb, do I need to purchase the bulb with the housing or does the bulb come out of its housing? Sorry for the machine gun fire questions.
  • 8,404 Answers
Take your mag light to the hardware store ... your frently hardware man can get you what you need.
Posted on Oct 04, 2009
Odd problem with ceiling fan and LED
This is a common issue with LED bulbs in the application that you have it installed in, When you changed the socket it reset the unit. Most of those wont ever see an LED because the LED wont draw enough current. Then control box depends on a current draw in order to stay on. LEED bulbs don't have enough current draw.
Oct 12, 2017 | Dryers
Why choose H4 LED lights instead of other models?
Installing LED aftermarket bulbs in a headlight assembly designed for halogen bulbs is ******* and throws less light on the road and causes more glare. They are NOT legal drop in replacements.
http://ricksfreeautorepairadvice.com/headlight-replacement-cost/
Headlight replacement cost Ricks Free Auto Repair Advice
Sep 29, 2017 | Cars & Trucks
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
The light on my Ashdown mag 300 combo input level does not light up. How easy is it to fix. Electronic places charge 85.00 just for a quote and 85.00 and hour plus parts to fix it. HELP!.
If you mean the light in the meter, those can be hard to replace and mosts shops would replace the meter itself which would up the cost. It is probably a 12 or 14 volt bulb(s). Look at the back of the meter and see if there is a removable socket to get at the bulb... if not, then the bulb(s) is internal and probably a soldered in grain of wheat bulb(s). If you have never worked on meters before it takes GREAT care to keep contamination out when working on them. I would certainly not pay $85 to have bulbs replaced... use an external lamp if you really need to seee the meter... one of the little LED ones would work.
Sep 12, 2011 | Ashdown MAG C115-300 Combo Bass Amp
How do i remove the led bulb in my 3D cell Mag-lite dl
http://www.takeitapart.net/archives/mag-lite-2d/
May 14, 2010 | Camping, Backpacking & Hiking
Vintage AMF Generator light kit new in box
Before you do anything else, carefully examine the filament in the rear bulb for any breaks. Shake it and see if anything moves. Replace with an equal wattage flashlight bulb and see if it works then. If I remember those generators correctly (jeez, it's been a long time), there was one wire to the side of the bulb and one to the little tip at the end of the bulb. It doesn't make any difference which goes where since it is DC. If you are interested in upgrading a bit, Mag-Lite sells high output LCD replacement bulbs for about $18 at Home Depot or Lowe's. They are very vibration resistant, put out about 4 times as much light as a tungsten bulb with the same voltage, and last a LOT longer.
Jun 28, 2009 | Classic Accessories Classic Bicycle Dynamo...
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
Mag lite
I have a regular AA Mag light that had industrial strength batteries which corroded.I did get them out but the bulb holder on the light broke.(The main bulb holder where the twist on switch is.)
Jun 12, 2008 | MagLite - Mag Charger System 110v (M)...
Streamlight  Sl 20 Xp Led Rechargeable Flashlight Full Size Logo
190 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
