Question about Mustek GSmart S55 Digital Camera
Wont turn on
When ever i try to turn on it does 3 chimes and won't turn on or charge
  • buddhiman651 May 11, 2010
    Here is your Solutions
    » Canon » Fuji » Kodak » Nikon » Olympus » Panasonic » Samsung » Sony
    buddhinma3
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
My inspiron 1545 wont turn on battery and charger are fine can anyone tell what could be wrong
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 23, 2012 | Dell Inspiron 1545 Notebook
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
Got the E3 code, replaced the board. The new board won' even fire up. Thoughts?
Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
How dose the chime work on a timex watch
Try to find solution here:
http://www.timex.com/gp/node/n/255235011/190-2521384-6105829?ie=UTF8&timexBrand=core
Rate me, please.
Jul 23, 2009 | Casio DB36-1AV Wrist Watch
Remote wont program
Is this the procedure u are using? this is from the factory manual.
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
1. Turn ignition to the RUN position (as far as you can go without starting the engine).
Wait for chimes to stop.
2. Using original programmed remote, press and hold the UNLOCK button on the
remote for between 5 and 10 seconds.
3. While holding UNLOCK button, and before 10 seconds passes, press and release
the PANIC button. A chime will sound to indicate that the transmitter programming
mode has been entered.
4. Within 30 seconds of the chime, press a button on all remotes to be programmed
into the system including any previously programmed remotes, a chime will
sound after each remote has been programmed.
5. Turn the ignition OFF to exit the transmitter programming mode.
6. Test Remotes
Apr 09, 2009 | 2006 Dodge Durango
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Mustek GSmart S55 Digital Camera Logo
51 people viewed this question
Top Mustek Cameras Experts
Mohamed Ismail
Mohamed Ismail
Steven Wander
Steven Wander
Are you a Mustek Camera Expert? Answer questions, earn points and help others
