Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Starter Cranks slow. New Battery - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    Sergeant:
  • 308 Answers
If the starter of your car crank slowly it means that there is a problem in the starter assembly.The owner of the car should work on the starter . the owner of the car should be able to locate and repair the starter .prepare the tools and equipment in repairing the starter .So that when the starter will function properly.First you have to remove the starter to the engine :disconnect the starter magnetic switch to the ignition switch and the battery.And dis-assemble the starter : first remove all electrical wires from the starter motor,remove the bolt from end head cover and cover band, remove frame assembly ,remove the solenoid remove the bendix drive pin,remove the pinnion housing, remove the lock ring,then remove the pinnion gear assembly.check if there are worn out or malfunctioning parts then repair or replace them.after repairing and replacing the worn out parts then assemble and install the starter back to the engine. If the owner of the car can't do the job done the owner of the car should go to a car shop mechanic , and let the car mechanic do the job.
Posted on Oct 05, 2009
  • jose_cruz2 Nov 25, 2010
    I would also suggest testing for voltage drop on the cable running to starter. Could just be a bad cable with corrosion.
Hard to start when hot
Posted on Feb 04, 2012
I have a toro 16-44 mower and won't start. I have a new battery fresh oil and clean plug. Cranks for a second then slows to a stop. Crossed solinoid with same results. Starter??
Sounds like bad starter or cables. Are the cables getting hot?
You say it CRANKS for a second, not RUNS for a second. If it stops CRANKING, it can't be fuel or carb or air filter or jets. Unless you meant it STARTS then DIES, THAT would be clogged jets.
May 02, 2015 | Toro Garden
1991 ford ranger 2.3 cranks slow no start
You don't mention the starter itself so that would be something to check.
Feb 28, 2015 | Ford Cars & Trucks
1989 fi50 std 4.9l cranks slow, starts, take a long trip...60 miles, shut it off and it is dead, no crank, nothin....wait 1/2 hour starts, still cranks hard then runs....can you help???
starter worn out.. battery with shorted cells..check these.. test the battery for load bearing capability.. it may need replaced..
Dec 28, 2013 | 1989 Ford F 150
WHEN I TURN THE KEY JUST CLICKS HAS NEW STARTER NEW SOLENOID NEW BATTERY
Is your new battery fully charged? Maybe you need to go slow with a step-by-step process.
The most common cause of a non-starting car is the battery. It is either weak, (low voltage) dead, (zero voltage) or has bad connections. (corroded or loose) I will assume you have a fully charged battery with good connections. (both to battery and starter relay)
If you remove the starter switch lead (small wire) from the starter relay and apply +12v from the battery to its respective prong or lead on the relay, and your starter cranks, your starter switch is faulty. (not to be confused with your key switch). If you jump the two large wires together on the relay and it cranks, then the relay is faulty. If you jump the two large wires together and nothing happens, then starter is faulty, or wires to starter are loose or broken. Picture of starter switch prong on the relay is pictured. NOTE: sparks are to be expected, so don't be too scared.
Dec 16, 2013 | 1987 Ford F 350
Engine cranks slow
What engine does it have some with overhead valves need the valves adjusted to cure that problem . I need more info to help you Like is it the battery bad starter ran out of oil ect
Dec 08, 2013 | OEM Replacement Parts Garden
1998 Chevy 1500 4.3 L new battery,new alternator and new wire to starter. Truck cranks and runs for awhile but then it dies.mfound that if ya take the small wire off the battery the truck dies. Is this the...
If its a slow turn over then check the engine to battery earth cable ,if this is ok then check the amperage draw and if excessive then renew the starter motor as the windings indise the motor have the insulation breaking down
Mar 04, 2013 | Chevrolet Blazer Cars & Trucks
2000 CAVILER TURNS OVER BUT WONT START NEW BATTERY BUT CRANKS SLOW 58 PSI FUEL
slow cranking with new battery would indicate a weak starter
Sep 16, 2011 | 2000 Chevrolet Cavalier
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
Starter cranks slow
By your description I would say BATTERY. Don't know how old the battery is. The average life of a battery is about 3 years, sometimes less, sometimes more.
Mar 31, 2009 | 1999 Mitsubishi Montero Sport
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
437 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
