Question about Poulan Pro " Pro" Self Propelled Mower
Poulan 550 mower idle problme
Purchased a Poulan 550 Pro push mower about 5 months ago. Now having problems idling, revs up and down (but not off) in 3-4 second cycle. Still cuts grass but guzzles gas. Any solutions?
  • 148 Answers
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
Why does my poulan 2075 runs with choke on but not when i push the choke in?
Crank seals could be leaking air in,or carb settings incorrect.screw both mixture screws right in,then out 1.5 turns..set low mixture screw for highest idle,you may need to unscrew the idle screw a bit to keep revs down.adjust H mixture screw at full revs,to get max revs,then unscrew 1/4 turn.may need to reset idle
Jul 23, 2014 | Poulan Garden
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
I have a poulan pro 550 Briggs and Stratton Lawn Mower. I need to find theOil Realease Button
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Sep 24, 2010 | Poulan "Poulan" Push Mower
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan push mower question
Check the engine manufacturers web site. You will need your engine number. .....You will find an on line diagram and part numbers for your engine. Also, Most Mower Parts stores have the same thing !
Sep 06, 2009 | Poulan "Poulan" Push Mower
Poulan Pro " Pro" Self Propelled Mower Logo
704 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
