Question about Proform 810 TR Treadmill
Profom frontrunner.Power,lights,no motor or incline.3yrs old.
We have the profom frontrunner. It's about 3 yrs old. It was working fine until we moved it. The power comes on and the lights but no motor or incline! Any ideas?
  • 3 Answers
I had the same problem-only one of my programs would work, and the rest of the buttons (even start) would not work. I used some scissors and carefully cut about a 1/2 inch in the plastic inbetween each of the copper strips in the ribbon cable. Then I seated each one individually (put them back in the white plastic thing) until I found the one that was freezing all of the other buttons up. Now all of my buttons EXCEPT for the one that was working before work. I can live without 1 program if it saves me $300
PS-mine also stopped working after we moved it, but when I told an "expert" that he said it wouldn't just stop working because I moved it....I think moving it DEFINATELY had something to do with it.
Posted on Aug 23, 2010
I have a Proform 970 Treadmill and the speed function is not working properly on the console, help
Run the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor, and see the instruction. God bless you
Jul 16, 2013 | Exercise & Fitness
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 27, 2012 | Exercise & Fitness
Lost instrutions for exercise bike profom 760HR
go please to the next web : www.fitness.manualsonline.com or www. iconservice.com
God bless you
Jul 02, 2012 | Smoothfitness Smooth Fitness 76 HR Pro...
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
Lower incline
Dear Sir:
I STRONG recommend RUN the calibration Software Inmediately, for eay Diagnose and troubleshooting, most of them instruction has coming in the Hood of Motor, follow the instruction or use your instruction manual.
Adjust the sensor speed attached the diagram. Tight the wires from sensor speed. The sensor speed can be faulty. Adjust the Pot with the gear in the same motor, both can be faulty. And finally the main motor board can be wrong. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua.
Feb 12, 2012 | Proform Exercise & Fitness
Only one program works. you can start manual but have no control over speed or incline.this is a proform frontrunner
Dear Sir:
I will help you inmediately.
SOLUTION: a. Remove the key from the console and unplug the
power cord. Remove the screws from the hood and
carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley
. Turn the Pulley until the Magnet is aligned with
the Reed Switch. Make sure that the gap between
the Magnet and the Reed Switch is about 1/8ó. If
necessary, loosen the Reed Switch Screw and
move the Reed Switch slightly. Retighten the Screw.
Re-attach the hood, and run the treadmill for a few
minutes to check for a correct speed reading.
Please check it and contact me if there are any additional help. blessing. sincerely.
E.Cuadra
Managua, Nicaragua
Sep 13, 2011 | Proform Exercise & Fitness
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
The treadmill will not incline
Try calibrating the unit first, if this does not work than check below:
1. If the incline moves but you will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad and needs to be replaced.
2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. Remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4. If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced.
Feb 20, 2010 | Exercise & Fitness
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
3 yrs old model; worked fine then no lights on front panel
i hate to tell you this, but more than likely the circuit board behind that light has gone bad. It is a costly fix at several hundred dollars, and this isn't the first one i've heard that has done this...
Mar 13, 2009 | Bosch Evolution 300 SHE43M0 Built-in...
Proform 810 TR Treadmill Logo
799 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
