Question about Garden
How do i change the blades on a honda hru 19r mower
    Problem Solver:
  • 6 Answers
Make sure u have the right socket for the nut blades must be upwards when puting them on
Posted on Oct 11, 2009
HOW MUCH ENGINE OIL GOES IN A HRU 19R MOWER
approx 0.6L of 10w40 0r 10w30
Mar 05, 2015 | Honda Garden
Remove and replace clutch cable on a Honda lawnmower HRU 216 ?
I would suggest you have a Honda mechanic do this repair !
Feb 13, 2015 | Honda Garden
How do i change the mower blades on my honda hru19d
Check this site for changing mower blades. Seems straight forward:
HOW TO CHANGE LAWN MOWER BLADES
Feb 11, 2015 | Honda Garden
HOW IS USEING HONDA`S HRU 19R CUT GRASS MACHINERY
powerequipment.honda.com/lawn-mo...
Oct 19, 2014 | Garden
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
How to set the linkages and adjust a carburettor on a Honda HRU 195 mower
Turn the engine off, Put the throttle
lever to the HIGH position. Loosen the
pinch bolt nut on the governor arm a
turn or two; just enough that the arm will
move on its shaft.
With one hand, move the governor
arm so that the throttle plate of the
carburettor is wide open. With your other
hand, use smallish pliers that's
why there is a flat on the shaft to turn
the shaft in the same direction. Hold
everything in that position and tighten
the pinch bolt.
You've just taken all the slack out of the governor linkage.
Recheck the choke, idle and maximum RPM
and you've done all the adjusting
you can do.
Nov 25, 2010 | Honda Garden
I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
May 02, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Mixture adjustment honda hru 173
Hi this most honda engines dont have a mixture adjustment screw they only have a air bleed adjusment on the front of the carby close to the head though you can only move it a bit either way on some others should be about 2 turns out from closed, the main problem that honda engines have is they will still run with water in the carby , I would try cleaning out the carby bowl first its only held on with a bolt in the centre.
Jul 31, 2009 | American Standard American Lawn Mower...
Can't figure out how to change it or take it off for sharpening
you find the right size socket that fits it.(it: the bolt in the middle of the blade under the mower. Then hold the blade as you turn the socket wrench, sometimes this will be hard. this is how to do it
May 21, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
290 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
