Question about GE Televison & Video
Looking for a manual for GE TV Model #19GT320 ,It has a Menu botton ,but I do not have a Remote
SOURCE: Can't get cable remote to operate GE 19TVR62
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
Posted on Dec 23, 2007
  • 346 Answers
SOURCE: Lost remote control of TV HCT model TVD 133S
you can use the menue button on the tv itself
Posted on Dec 01, 2008
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
  • 7 Answers
SOURCE: Lost manual for ge universal remote 24912
I found it finally!!! This stupid $10 remote was pissing me off, I couldn't find anything but ppl needing the same help as me so I thop this helps you!!! This link worked for me, and you prob want the 4 digit code b/c I also have a Sanyo I had to program. good luck, hope this helps!!
http://www.jascoproducts.com/support/universal-remote-codes.asp
-Summer
Posted on Mar 08, 2009
the q guy
  • 393 Answers
SOURCE: GE UNVERSTAL REMOTE RC24912D
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Apr 29, 2009
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
My Toyota Avensis 1.6 2007 the trunk locks automaticly.. when I go to open the trunk it doesn't open,, only if I press Unlock botton on remote! how to fix this?
Battery may be dying in remote and your car should have a setup menu which is accessed through the mileage display. try looking there, also refer to your owners manual if you still have it
Jan 04, 2015 | 2007 Toyota avensis 1.6
Using the menu function on GE 24914
if you have not tried it GOOGLE that model number with "manual" to see if you can locate a owner manual for it.
Apr 03, 2012 | Universal Remote Control Televison & Video
Back box on bottom 1/2 of screen happened a year ago. Can' remember what to do. Help I have big Toshiba CZ32V51 with universal removte Phillips
Can u get into ur tv menu with the universal remote?If u can't tries it with the tv manual buttons look at on the botton of ur tv have manual button said menu.Press it go into the tv menu.Look inside the tv menu for functions like Close Caption like CC1,2,3 and Text 1,2,3 make sure all CC1,2,3 and Text 1,2,3 turn it to all off.Black square box will disapear.Can't do it in the tv manual button etheir.Try website like Remote.com to buy the tv origial remote to close Close Captioning and Text 1,2,3 to all off.
Apr 15, 2011 | Toshiba CZ32V51 32" TV
Need the original settings for an 42 LE 530 tv
they is no reset botton .
to reset -switch off your tv from mains plug leave it off for 5mins and switch the tv on.
You may need to purchase a programming remote from LG. The user remote that comes with the TV doesn't have the MENU button. The manual also listed a programming/cloning box by Zenith, I have a cloner box for RCA and it has a reset button on it. I had to download the manual for the same TV from http://shop.retrevo.com/ they didn't have a listing for the LG but the Zenith has the same model # and is the same TV as far as I can tell. You may be able to access the menu using the menu button on the front of the TV . Hope this helps.
Apr 14, 2011 | LG Televison & Video
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
Batteries went dead in remote - a GE Universal remote - don't have book to get code for TV to reprogram to use r
Here's a list of GE Universal remote manuals. Try looking in here. Or you can reply with the model number of the remote and TV and we'll find it for you.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=ge
Apr 06, 2009 | Sanyo DS31590 31" TV
Codes for daewoo tv, ge remote model 24912
Dec 13, 2008 | GE JASRM24912 Remote Control
RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from Electronicadventure.us for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Nov 15, 2008 | RCA F32650 32" TV
Televison & Video Logo
204 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
