Question about Canon PIXMA MP600 all-In-One InkJet Printer
When I go to print a file on the Canon MP620 Printer, I get an error message that says to load paper in the rear tray, but the tray has paper. I believe it might be a sensor problem. HELP!
  • Canon Master
  • 13,433 Answers
Clean the printer and the back tray, look for small swich / button or similiar. that may have become stuck or is not getting pressed.
Unplug the machine and try again after a few minutes.
if the problem remains press and hold the stop button for 5 seconds and then release it.
Posted on Oct 04, 2009
Error load paper and beep when i print
More info would be helpful. Like exactly what is the control panel message. However, from your description it sounds like the machine is looking for a paper size or type not loaded or wants paper loaded in the manual feed tray. Check your driver and see which paper tray is selected and what type paper as well as checking the printer to see if the tray is set to plain paper or some other type.
Nov 24, 2014 | Canon ImageRunner 2525 Copier Canon
Canon pixma pro 100 - "support code : 1000 no paper. Load the paper in the rear tray correctly and press the RESUME button on the printer". How do I fix this?
Try again! Remove the paper from the rear tray. Turn off the printer. Load the tray again making sure that it pressed frimly in and not over loaded - say about 30 sheets. Turn printer on again and see if it is ok. If still the same problem, get in touch with supplier or maker.
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
I wanted to print a form from the internet The printer said The rear loader is empty I only use front loader and it is full I did not ask it to change to rear loader I want to use the front tray as I...
It could be several issues - although commonly when a printer moves from it's default tray it's due to a paper size conflict. The form you are trying to print may be a legal size form (8.5x14) or a a non US standard such as A3. Regardless, if the size is different than what's loaded in your main paper tray it will move to the secondary tray or to the MPF (Manual Paper Feed) tray looking for the appropriate size.
If you don't have the appropriate paper, you should be able to enter your printer properties and adjust the settings to scale the document to fit to page.
May 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Printer screen says that there is no paper when I just put some in the front feeder. I have a Canon MP620.
The MP620 also has a rear slot for smaller paper sizes. Did you perchance submit a print job for some
alternate paper size and the printer is expecting a rear load of paper?
Mar 22, 2011 | Canon PIXMA MP620 All-In-One InkJet...
I have an envelope stuck inside my canon mp620 printer somewhere. How do i get it out?
There are three areas for paper jam clearing.
1. Under the scanner cover
2. At the rear of the printer is a small door with rollers at the top. it comes away from the printer from the left. There are some small pins to hold it in on the right. Swing it out to remove the door.
3. The cassette tray. Remove the tray to expose jammed paper or envelopes.
Here is the diagram for the rear door.
Do not touch any components inside the printer.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
MP630 print ERROR - ''There is no paper. Load paper and press OK''
You have to set up NOT "cassette"(in this case "cassette" means the front side of the printer where you are supposed to place a cd or dvd) Choose "rear tray" ! You might have changed the settings by mistake. I had the same problem. I was wondering why is the printer not taking the paper but i figured it out. Try the settings on the mini display of your printer.
Jun 10, 2009 | Canon Office Equipment & Supplies
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
