Question about Cameras
The selector knob on the top of the camara appears to not select the same function indicated on the knob. very strange eg select still shot and comes up on screen recording and also will not focus.
  • 22 Answers
SOURCE: retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Posted on Jul 02, 2007
  • 183 Answers
problem is caused by the sprung mechanism within the control knob sticking remove the knob completly, try to squeeze together in your hand to release and then spray with a wd40 type product, if this fails you will need to replace the knob, the knob only pulls off. Engineer
Posted on Jul 28, 2007
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Posted on Dec 10, 2008
  • 1116 Answers
SOURCE: my stitch selector keeps turning around and around
You will need to take the machine in for service.
Posted on Feb 27, 2010
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
Can you confirm if the top element should be coming on when selecting just fan oven? If had a look at the over selector switch all appears to be of ok with the switch selecting the top element as well as...
Correct, the grill element should not come on when using the fan oven.
Using the fan oven
The air inside the oven is heated by the
element around the fan situated behind the
back panel. The fan circulates hot air to
maintain an even temperature inside the oven.
HOWEVER
I think you are doing this
Using Hot Air Grilling
This function uses both the grill element and the
fan. Turn the function control knob to the
appropriate position. To achieve optimum
cooking results, it is advisable to place the oven
shelf in the middle position while the oven tray
should be inserted at the bottom.
IMPORTANT: When using the hot air grilling
function, set the thermostat knob no higher
than 175°C, which is between the 150°C and
200°C setting, to avoid overheating the front
of the appliance.
The door MUST be closed while Hot Air
Grilling.
http://kitchen.manualsonline.com/manuals/mfg/zanussi/zcm930x.html?p=10
Dec 01, 2017 | Zanussi ZCM930X Dual Fuel (Electric and...
My camera wont stop processing!
Sounds like you might have the selector knob on the top of the camera rotated into the video position rather than the single shot position.
I had this happen to me several times before I discovered that the knob was getting rotated when I removed the camera from its case.
Since then I'm always careful to check the knob position when I remove the camera from the case.
Jun 25, 2010 | Kodak EasyShare Z1275 Digital Camera
My stitch selector keeps turning around and around
Feb 27, 2010 | Singer Featherweight II 117
2004 LAND ROVER DISCOVERY SE
im not certified in this but ill give it a shot in my opinion i believe that u would hit the function key scroll threw first number with selector knob then there should be another button that selects and moves to next number with selector knob put in next number in my opinion i think its like the old nintendo setup when you get the high score you put in your name either at begining or end with the control pattle
its just a shot in the dark tryin to help my sterio in my truck had a little problem like that but no codes you just have to find the next button
May 02, 2008 | Car Audio & Video
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Stops midcycle, restarts when you lean on it
If the problem lies with the contacts, then the knob is not the direct problem, it would be the selector switch behind the knob. Although I don't understand how leaning on the to makes the machine work. Are you sure it is not the switch that indicates when the lid is closed? Either way, Yes!! you can simply just change the switch over.
Jul 27, 2007 | KitchenAid KAWS850L Top Load Washer
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
