Washer transmission oil leak?
I have a GE washer model WPSR3100W0WW. It has been in storgae for probably at lesat 3 years. I ran it through two cycles and it worked fine as far as I can tell but the metal bottom is covered with what appears to be some sort of old oil residue. I assume it to be from a transmission oil leak. It is not currently dripping and I cannot tell just where it came from. Do these transmissions contain a fairly thin thype of oil/fluid in sufficient quantity to completely cover the bottom of the washer? I can get a replacement transmission for under $150 but I'm not sure that is the culprit.
    President:
  • 1,304 Answers
They do contain oil
it would be best to run it till it dies
the tranny woont get any worse than it is
and eventually you will have to replace it
Posted on Oct 04, 2009
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
After some loads, what appears to be gear oil (about 8 or 10 streaks of it) shows up on the inside of the agitator. I thought it was just years of buildup, so i cleaned it and ran through a small load. ...
GE washers are notorious for transmission leaks. Personally, I wouldn't spend much time or effort on a major repair of a 14 year old washer. Suggest you contact a local parts house and see if the upper seal is available as a kit. Other sites suggest that this transmission is no longer available new, and even then it's a $250 part. If you ruin one load of clothes with transmission oil, you're probably halfway to the price of a new one.
Apr 19, 2017 | GE WWRE6260D Top Load Washer
Brown oil is leaking from the bottom of the washer
The only place oil can come from is the transmission. If you do not have a big leak, it may run a long time (read: maybe a year or more) before low oil level in the transmission causes major appliance damage, but it's time to start looking for a new washer. Many washers these days do not even use an oil filled transmission. Current GE machines do not, and the Whirlpool models comming soon don't either. If you can afford it, the front loading LG washers (which are direct drive, thus no transmission or clutch, and have a 10 year motor warranty) are the best, in my opinion.
Jun 05, 2010 | GE Washing Machines
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
My washer is leaking grease or oil on the floor under the machine
Hello and welcome
You said, My GE washer is leaking a tan colored oil underneath the unit. I suspect it's the gear case leaking. How difficult is it to replace the gasket or seal. I like to fix things and have tools. If the gear oil is leaking this usually means the transmission is shot and on it's way out. It is not cost efficient to have it replaced. 99.9 % of the time you throw it out and buy a new washer.
For the cost of the Transmission and the labor.
you can buy a new washer.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Feb 09, 2009 | GE WBSE2090A Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
GE Washer WPSR3100W0WW roars like a freight train in spin cycle
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
Jul 03, 2008 | GE Profile WPSR3120WWW
Washing Machines Logo
385 people viewed this question
Top Washing Machines Experts
