Question about GPS
I have an old magellan gps 2000 i cannot find out
I have an old magellan gps 2000 i cannot find out how to set the date and i set the time in the initialize and it does not change on the nav screen
    President:
  • 1,111 Answers
Its in the options menu under the time zone
example: if you live in the east usa, set it to eastern time and check off eastern time zone and ck the box marked daylight saving time
Posted on Oct 05, 2009
  • Ben Dover Jul 29, 2010
    GO TO THE OPTIONS MENU, THEN SELECT TIME ZONE AND SELECT YOUR TIME ZONE...ONCE THE SATELLITES HOOK UP (LOCK ON) YOUR TIME WILL BE SET AUTOMATICALLY>>>THATS THE ONLY THE ONLY WAY TO SET A MAGELLAN 2000
SOURCE: Magellan Maestro 4040 GPS - File Error / Inaccessible Maps
Call Magellan Factory them TECH will help you fix the problem.
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: magellan gps 2000 won't lock
Possible solution, at least my GPS2000 finally locked up. Initialize; enter current location and time; wait until there are more than four (I had seven) satellites available; find a location nearby that has a clear view nearly to the horizon in all directions; place the GPS2000 on a stationary base with the antenna as horizontal as practical; wait; mine finally locked up after perhaps 30 to 40 minutes. Patience and an abundance of satellites, I think, are the answer. Good luck.
Posted on Mar 22, 2009
  • 4 Answers
SOURCE: maestro 4250 frozen after incomplete 2009 map up date
Call Magellan tech support at 1 800 707 9971 before calling make sure your product is registered.I had a similar problem with 4250 model and there was an error that showed 90% into the uploading process and my unit froze up . I received a repair number and shipping the unit back and I was`told will take a week.
Posted on Apr 04, 2009
SOURCE: cant change time on gps
Press RESET button and torn on it again. Should be OK
Posted on Jun 27, 2009
  • 1111 Answers
SOURCE: how do I change the battery in a magellan roadmate
remove the the four screws from the back cover and the back will come off exposing the battery.
careful while removing the cover, the speaker wire is connected to it but you can change the battery with it connected.
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired, or the part here
or buy the port here
if you need further help, just let me know
Posted on Aug 19, 2009
Testimonial: "Thanks for the help..changed out thr battery...old one was all swollen and seemed close to rupture. Everything is good now...thx."
On my Magellan 2000 GPS I'm am try to rreset the date how do I do this?
The GPS gets date and time information from the satellites so automatic.
May 24, 2017 | I'm Watches
How toset the time ona magellan triton 400
Do a MENU>>VIEW>>SETTINGS .. go do the menu as the time and day are hidden from the original screen .. Date and Time will appear .. highlight it and make your corrections.
Nov 04, 2010 | Magellan Triton 400 Handheld GPS Receiver
How do I reset the time?
Actually the time is sent to you by the GPS satellites. To set the time do a MENU>>VIEW>>SETTINGS and use the down arrow to scroll to the date and time and then set your GMT and Daylight Time Settings. For example: New York is now GMT -0:500 DST is set to OFF
JG
Oct 13, 2010 | Magellan Triton 400 Handheld GPS Receiver
I cant set the time on magellan triton 400
Assuming that you have the latest firmware version installed .. do a MENU>>VIEW>>SETTINGS .. scroll down the menu using the down arrow until the page moves. You will see the date and time category .. do your change.
Sep 26, 2010 | Magellan Triton 400 Handheld GPS Receiver
Cant set time on magellan trton 400 gps
Go to MENU>>VIEW>>SETTINGS .. Go down the menu until you reveal more choices. Pick Date and Time and make your changes.
Feb 23, 2010 | Magellan Triton 400 Handheld GPS Receiver
I also have a Magellan Triton 300 and I can not change it to my time zone.. how can I change it?
From the user manual at http://www.magellangps.com/assets/manuals/MagellanTriton_300_400_500_UserManual.pdf
it says:
Setting the Time Zone
The time and date information will be computed from information from the GPS satellites so there is
no requirement for you to input any time or date information. However, to make the time accurate
for your location you must select the correct time zone.
1. From the Map screen press MENU.
2. Select View.
3. Select Settings.
4. Scroll down and select Date & Time.
5. Select the Time Zone field.
Press button
momentarily
Fundamentals
5
6. From the drop-down menu, select your current time zone. (Time zones are not changed
automatically when travelling. If you travel to an area with a different time zone, you will
need to change it here for accurate time information.)
7. Repeat the process for the Daylight Savings field.
8. Press ESC when done.
Jan 02, 2010 | Magellan Triton 300 Handheld GPS Receiver
My Magellan Triton 500 does not display the correct date or time. Can you help?
Assuming that you have the latest firmware installed. Do a MENU>>VIEW>>SETTINGS and then using the down arrow to scroll down. The Date and time and language and power settings are out of sight. scrool down and you will see date and time.
Dec 03, 2009 | Magellan Triton 500 Handheld GPS Receiver
I need help changing the time zone on my magellan triton 300... I need help even getting to where you can change the time zone
Assuming that you have the latest firmware installed ..then do a MENU>>VIEW>>SETTINGS .. no scroll using your down arrow so the screen shows you the HIDDEN settings and you will see date and time. The rest is easy.
Aug 07, 2009 | Magellan Triton 300 Handheld GPS Receiver
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
GPS Logo
214 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
