Question about HP Compaq FS7600 17" CRT Monitor
Moniter says out of frequency set resolution lower or see user guide
I dont have the user guide and i cant set anything cause it wont show up on my monitor
  • wontgetlost Feb 27, 2008
    right after MS did an auto update and i rebooted, I get the same thing "out of frequency range" . I tried safe mode which works except there are no options to change the frequency settings, there's just the "default". I tried system restore and that also did not work. In the end, I just replaced the video card with an old one i had lying around and that did the trick.
  • ramseer6 Dec 30, 2008
    out of freequency set resolution or seeuser guide
  • 205 Answers
The settings you need to change are actually on the computer's video hardware. Assuming you are using a Windows machine, right click anywhere on the desktop. Select Properties, then the Settings tab. You should see a resolution slider that you can adjust. There should be an Advanced button that will give you access to other settings that are possible with your hardware. This is where you can adjust the frequency.
If you are unable to see anything because of this problem then you may need to boot into Safe Mode to correct this. Let me know.
Good luck.
Posted on Dec 22, 2007
  • 383 Answers
E-mail CHID: 5304 ... meeting the minimum system requirements it may be time to upgrade or you may want to lower your system settings, such as decrease the resolution.
Good Luck, Please dont for get to Vote/Thank You.
HOW DO I SET MY OMRON TO SHOW HOW MANY MILES I WALKED
Hello there,
You dont need to friend, It does it for you. !!!!
You MUST calibrate the BEFORE use..
See the user guide . 'stride length'
If the initial settings are not correct, the measurement results may not be accurate
Dpwnload here.
http://healthcare.omron.co.in/manuals/HJ-321.pdf
You must set it to miles instead of Kilometres. See manual
Sep 18, 2014 | Omron Hip Pedometer With Holder -...
The frequency is set to high on my computer so now the monitor wont display anything and I cant lower the frequency because I cant see it on the monitor
what OS? windows?
what a PC?
if windoz, go to safe mode, and set the the resolution.
then boot.
safe mode is found , by pressing the F8 key, repeatably as you boot,
then not stating what OS ,makes an detailed answer inpossilbe.
Oct 01, 2013 | Gateway FPD1975W 19" LCD Monitor
Cant see anything on the screen
See my publised guide entitled:
My Computer is not turning on!!! Is it dead!!! No POST!!!
Yes some-times it can be an easy fix, hopefully it's a loose connection.
Aso make sure that the monitor is pluged into a horrizontal port on the rear of the computer chassis if one is present. In other words connect the monitor to the graphics card if one is installed.
Take care!
damnor01
Apr 29, 2012 | Gateway GT5674 Desktop PC
Acer monitor wont turn on or off?
This type of problem is usually caused by a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and repair the power supply board. If you can do a little soldering then you can repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2016w-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Nov 29, 2011 | Acer AL2016W 20" LCD Monitor
My hp monitor S5500 when boot on it desplay out of frequency range and set resolution lower or see monitor users guide. What can i do to clear this information.
It means that the resolution set in the pc is higher than what your monitor can handle. Boot in Safe Mode, go to Control Panel > Display and in the Settings put a lower resolution - 800x600.
Jul 15, 2011 | HP Computers & Internet
Moniter screen not displaying anything except the resoluton is too high or oo low frequency not matched how solve these problem
does this happen right after you power up your computer? or after the windows loading screen? if after the windows loading screen, what you can do is to restart your computer. while booting up, press f8 repeatedly and select safe mode.
If you successfully logged in to safemode, you can lower down the resolution.
you can do that by Right cliking on the desktop, click on properties, then change the screen resolution to a lower one.
Hope that works.
Feb 06, 2011 | HP Pavilion a705w PC Desktop
I cant understand anything! where is the solution? i need instruction or a guide to repair it.. something like the mainboard plan, or where can i get electronic...
I doubt you will find a circuit diagram for a monitor. They are NOT user servicable.
IF you want it repaired, take it to a repair shop. IF you cant understand anything, just get a new monitor.
It would cost you more buying the equipment to diagnose the faulty part, then buying the parts IF you can buy them. A new monitor can be had for about £90, it could cost you alot more to try and fix it
Jul 30, 2010 | Princeton Digital VL1716 17" LCD Monitor
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
Vivitar 8225 camera wont work its showing a screen msdc and a red led, manual says green led, cant get any thing else to work etc, and the red light is static, any ideas the vivitar website is **** no help...
Got this camera for Christmas- dumb disc user guide wont load- HOWEVER i found online source- downlaodable user guide
http://safemanuals.com/user-guide-instructions-owner-manual/VIVITAR/VIVICAM-8225-_E
Look for the little man reading a book next to the adobe PDF icon... it gives you everything
Dec 25, 2009 | Cameras
HP Compaq FS7600 17" CRT Monitor Logo
2,949 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
