Question about Samsung Digimax D53 Digital Camera
My camera is locked, reads "Card locked"? Can you help me correct, never had this before?
Take the card out and move the card tab on the side of the card up all the way and stick it back in quickly.
Posted on Oct 06, 2009
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Oct 04, 2009
We bought a 4GB SD Card, but the camera fail to format the card. We've tried formatting the card on computer but it still didn't work after inserting back in the Camera.
To correct a Memory Card Lock:
one the side of the memory card is a plastic toggle switch, slide it down and up again to reset the switch and then stick it back into your camera.. see if that fixed the problem.
SD SDHC Card Problems and Fixes Card Locked Card Error No Memory Card...
Jul 19, 2015 | Kodak Easyshare CX7530, CX7430, CX7330,...
My Canon camera says "Card Locked", I can't delete a picture or any other action, what can i do?
remove the memory card. Make sure the little notch on the left side is in the up position. If there is no notch, the camera will handle the card as locked. When all cards you put in the camera act the same (locked) perhaps the switch in the camera is defect. Check if the memory card slot is free of any debris. (use a magnifying glass and a strong light.
The switch on the card here is in the correct position.
Mar 31, 2015 | Canon IXUS 960 IS Digital Camera
My cannon reads card is locked, but the card is not locked. How do I get the camera to read the card correctly?
The card might be bad. Try a different/new memory card and see if you get the same message.
Jan 29, 2013 | Cannon Cameras
My digital camera says card write protected. changes many memory cards still the camera says card protected i slide the switch of the mmc up and down the screen still says card protected and i can't take...
Hello ranmer 9960:
First lets try the card in your PC to make sure the card is working. If it is working in the PC then its probable that the camera is not reading the lock switch correctly. Lets try setting the protection lock switch on the card in between the locked and unlocked position. If that doesn't work then we can try putting some electrical tape (because its thicker than cellophane tape) over the lock switch on the card This may help your cameras lock switch reader function correctly. Make the piece of tape wide enough to cover the lock switch on the card but don't cover the copper contacts.
Try these suggestions and if it works then give the thumbs up a click.
If not we can try something else.
Your FixYa team member Peter N.
Mar 28, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Message says can't read card, even when I put a new card in. How do I fix it?
Your camera is programed for SD memory cards from 8MB through to 2gig if you have put a SD card in the camera larger then 2gig it can't read it. If you are under the 2gig maximum then it's possible the SD card is in the lock position. At the top left corner there is a little white slider type switch make sure this switch is pushed forward to the top of the card in the direction of the gold contacts. Also a new card will need to be formatted for the camera to read the card properly. See page 11 screen shot I have provided for correct card installation.
Also page 12 for the formatting of the memory card.
Hope this is a help Robert in Canada
Dec 27, 2010 | HP Photosmart R827 Digital Camera
Micro sd card wont read
Check the SD card to see if the 'lock' is engaged. If so unlock and you'll be able to read. Other than that the other possibility is that your card isn't installed correctly. Remove it and check the pin orientation to be sure that it's installed correctly
Sep 23, 2010 | Kodak Zx1 Digital Camera
Cpu won't read memory card
look beside the memory card on the side of it says "locked" slide the switch back to unlock it and you will be able to transfer the pics.
Feb 13, 2010 | Computers & Internet
Canon G9 camera and G7 similar problem... checked out memory cards and they were reformatted. cards work fine in other digital carmeras I own. Can not get either camera to read a memory card
Usually this means there is a problem with the memory card part in the camera that reads the card. When this happens it will usually say either memory card error or card locked, even when the card is fine. Try emailing this site for help with this: www.camerasandparts.com All they help with are the Canon Powershot cameras and they're excellent for help with these models. Good luck with it. They'd be the place that could help with this.
Dec 31, 2008 | Canon PowerShot G9 Digital Camera
Canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Dec 18, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
AIPTEK IS-DV2
First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
Jul 08, 2008 | Aiptek IS-DV2 Camcorder
Samsung Digimax D53 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
