Question about RCA L50000 50" Rear Projection Television
Need a new replacement bulb for a m50wh725, where do i find it?
  • RCA Master
  • 5,138 Answers
Go to Encompass Electronics 1-800-638-3328 or Mats Electronics 1-800-628-1118
Posted on Oct 04, 2009
Replced bulb starts to power then fail red light blinks thre times
You might need a new housing! Sometimes, the housing can be damaged with a new bulb and it can caused the TV to want to shut off.
Mar 15, 2013 | Sony KDF-E60A20 60 in. LCD HDTV
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
I need to replace the bulb. Do I need to order the bulb only or bulb+housing. where is the bulb located on the back of tv? Thanks for the help
If you are looking at the back of the TV look on the left hand side to see if there is a access panel on that side of the TV - open it up and you will see the light bulb housing - take it out and look to determine whether you think you can replace the bulb by yourself or if you need assistance - I will say this most of the LGs are not soldered on they are put on using a small nut and they are easy to replace - 1 note is to order just the bubl if you think you can replace it yourself but DO NOT remove the bad bulb from housing until you get the new bulb so you can see how to hook up the new bulb :-) plus it usually takes about a week to get the new bulb in and sometimes people tend to forget how things were taken apart :-) Good Luck you will save money if you order only the bulb!
Thanks,
MC
Oct 28, 2010 | LG RU-52SZ51D 52" Rear Projection...
WD-57731 every 6mos bulb replacement
You need to make sure you have at least 6 to 8 inches of clearance behind the set. You may also need to replace the balast
Sep 08, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Need to replace primer bulb on a briggs & stratton lawn mower
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
Apr 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Need to replace headlight bulb in honda civic 2003
How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com
Dec 31, 2008 | 2003 Honda Civic
Samsung hdtv HLP5085wx no image. Smelled something burning and sparking, turned off the tv. Tried turning it back on = have sound, NO image!
OMG! Dude, your screen is just plain fried. You don't need a new screen though, You just need a new bulb for it. See, behind the screen is a light bulb (unless your T.V. is plasma screen), sometimes two or three, and that burning smell was the bulb blowing (like when you need to replace a light bulb in a lamp or something). I don't know where you can find a new bulb, but once you replace it everything should be fine.
Oct 05, 2008 | Televison & Video
Rca m50wh725 rear projection tv.
It has gone into protection mode. This is caused when a short circuit is detected by the power management system inside the tv. Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it. If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determine which section of the tv has failed and what components will need replacement. The cost of repair is always over $200 and could be much more, depending on the specific parts that need replacing. If the ICs have burned out the repair is around $400. The flashing of the standby light may mean something, but I do not know the diagnostic code RCA is using; most RCA models do not have any diagnostic blink codes in the set. Hope this helps. Let me know if I can help further.
Jul 06, 2007 | RCA L50000 50" Rear Projection Television
RCA L50000 50" Rear Projection Television Logo
150 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
