Question about HP Officejet 6310 All-In-One InkJet Printer
Where do i plug the lines from my 6310 all in one into my modem
    President:
  • 2,600 Answers
On the back lower right of the unit you will see two ports for regular phone lines and one port for en RJ-45 ethernet cable. The phone port are for a phone line to come into to accept faxes through a ground line. If you still have regular phone service, the line coming from the wall outlet goes into the port marked "line" on the back of the All-In-One. The other port on the back of the printer is for a phone line to hook into a portable phone, that way you can answer the phone if there is no fax. The other port, for the ethernet cable goes to the modem or router, however you happen to have it set up.
Posted on Oct 04, 2009
My ISP gave me a USB modem(Wanadoo ADSL) which i connect my telephone line and a USB to connect the modem to my pc.I bought a D-link DIR-825.Do i connect the telephone line directly to the DIR-825 or i...
Plug the modem filter in the wall, plug the modem into the filter, then plug the router into the modem. From there you should be able to set up your network or personal internet.
Mar 12, 2011 | D-Link DIR-825 Wireless QuadBand Router
How do i hook my computer up to my HP Officejet 6310 All-in-One printer?
You'll have to get a usb cable and physically connect the hp officejet 6310 printer to the computer and boot up the computer while the printer is plugged in and on.
You may have to download the drivers for the printer from the hp.com website. Enter the model # of the printer in the search or query line on the hp.com website to find the drivers.
Good luck on this.
Jan 12, 2011 | Office Equipment & Supplies
Im trying to hook up a router to this modem so i can plug in multiple internet connections but the router needs a phone line to be plugged in but do not know how. Any help?
hello, im confused here, have you a cable modem or telephone line. if you have a cable modem then you plug an ethernet lead rj-45 from your modem to your router.but if you've a telephone line then you have to connect a filter to you telephone box an a rj-11 lead from your filter to your router hope it helps
regards
shaun
Nov 28, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
HP 6310 Cannot send or receive faxes message at startup. Tried another phone line with same result.
This is a result of a fax modem fialure, Common in Hp's what happends is the all in one was plugged into a nakid phone line without a surge surpressor or what not and basically got zapped, other causes could be the modem just not functioning.
Point in case your going to need to have this repaired there is NO reset albeit Magic wand that a tech shakes at it to make it work.
Let me know your comments if you wish, please do not forget to rate. Thanks
Aug 25, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do I set my HP 6310 to pick up a smart ring line?
setting>select line.insted of use both manually select 1
Jun 25, 2010 | HP Officejet 6310 All-In-One InkJet...
All of my test fax are no answer. I have the
Your cable modem is not normally a source for telephone line that the fax machine will support. If you have telephone service through Comcast, You need to contact them about proper hookup to configure your fax line.
Apr 12, 2010 | HP Officejet 6310 All-In-One InkJet...
The phone line is correctly connected to the all-in-one but...
To be sure your phone is plugged in properly try picking up a different phone in your home with the fax also plugged into a phone line. The fax display should indicate "Phone off hook".
If the problem still persits, turn off the power to the printer/fax then turn it back on. This reboots the software and usually fixes the problem.
Aug 20, 2009 | HP Officejet 6310 All-In-One InkJet...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Just tried to hook up a new 6310 all in one. Can't get the fax to work Says an active phone line was not detected. The phone line when put back into the phone works ! Mike
Verify the phone line is being plugged into the correct jack, there are usually 2 - one for a phone and one to connect to your existing phone jack. See if your phone works when connected this way, if not then there is a problem with the jacks and/or internal modem in the fax.
Dec 08, 2008 | HP Office Equipment & Supplies
Phone off hook error message
perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01832&cc=us&lc=en&dlc=en
May 22, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
