Question about Whirlpool ART535 Top Freezer Refrigerator
Whirlpool 635 Hi, the fridge compartment is building about with about an 1nch of frost at the rear. Also the fridge roof is freezing with frost causing water to drip from the ice formed.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
To hasten the defrost process as suggested by Bob I would add you use a hair dryer at low setting. You wi shift the ice in a couple of hours.
Posted on Mar 09, 2008
  • 833 Answers
Fully defrost your unit. This takes about a full 2 days with the doors open and unit off. Clean and repair all door gaskets. Avoid leaving doors open or introducing large amounts of moisture into the unit. This will probably take care of it. If not, let me know.
Posted on Dec 22, 2007
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Nov 19, 2007 | Refrigerators
Fisher paykel fridge freezing up
25 years and still have not gotten monies worth?!?!?!?!?
Sep 15, 2017 | Refrigerators
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Fridge at room temp
Good day,
two common reasons fro this.
1. The fan motor in the freezer compartment has failed and is not driving air to the fresh food compartment.
2. The second common problem is the defrost system has failed, blocking air from entering the fresh food compartment.
First indication is frost building up on the rear panel in the freezer. Remove rear panel and inspect.
Here is an excellent tutorial on defrost system repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 04, 2009 | Whirlpool Refrigerators
I have a Kirkland Whirlpool fridg # ST14CKXK000 will not cool
Good day, here's a list.
1. The fan motor behind the rear panel in the freezer compartment not running. Replace.
2. Auto defrost system failed. This causes blockage of the airflow to both compartments. Usually can be identified by frost building up on the rear panel of the freezer section.
2A. the defrost system is made up of 3 parts.
First, the main defrost heater located in the freezer section, behind the rear panel.
Second, the defrost thermostat, a small round disk located in the same area as the main heater.
Third, the defrost timer, located on the roof of the fresh food compartment.
3. Failure of the sealed system, including loss of refrigerant, restriction preventing refrigerant from flowing thru the coils properly. The sealed system has a factory warranty of 5 years.
The ability and background to use a VOM meter are necessary to perform tests on 1, 2, 2A.
Need a qualified tech to perform tests on 3.
Nov 09, 2009 | Refrigerators
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer freezes, fridge below will not cool
if your freezer is still freezing fine, except for perhaps a slight softening of ice cream. this is a good sign. the second fan you are looking for is located behind the back wall of the freezer, emptying the freezer will gain you access to the screws to remove he panel. you should be able to hear the fan blowing when the freezer door is opened.if indeed the fan is blowing you may have frost building up on the rear panel, this would indicate a defrost problem( unit not self defrosting) and so much frost has built up that the air flow has been restricted to the refrig compartment
Nov 17, 2008 | Kenmore Refrigerators
Whirlpool fridge to cold
Both the thermostat and Adaptive defrost control are inside the fresh food compartment on top..
also check you damper it it is closing
let me know
Apr 04, 2008 | Refrigerators
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Whirlpool ART535 Top Freezer Refrigerator Logo
98 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
