Question about Intermatic T104 24h 208-277v Mechanical Time Switch
I have a brand new T104R and its installed correctly i think the electrician new what he was doing, but it seems the timer motor (TIME) does not move or change, the manual swich works and powers my equip. its wired with 240V (2x 120) > 120@ L1 and 120@L2 = 240
  • mlopes601 Oct 10, 2009
    Thanks,
    But, what i don't understand is the dotted line going from #1 to clock motor?
  • 75 Answers
It looks like the hots coming in should go to L1 & L3, not L1 & L2. i have a brand new T104R and its installed - 175525d.png
Posted on Oct 10, 2009
T104r timer manual switch not working, clock runs fine, on and off trippers work
The contacts inside the time clock have most likely warn out. If it is coming on randomly it is not making good contact and will create arcing, which is dangerous. Call an electrician, they may be able to replace just the internals.
Jul 26, 2016 | Intermatic T104R 208-277Volt 40-amp Timer...
How connect a new intermatic t104r 120v
T104 timer is 240Volts.
Not 120Volt
You can convert timer into 120V by changing clock motor from WG1573 to WG1570. This action will convert the T104 into T103.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
The T104 timer can be wired many different ways:
Copy following link for illustrations showing both T104 and T103 wiring
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment with specifically what you are connecting to timer, and I will comment back with more detail as needed.
Oct 07, 2012 | Intermatic T104R 208-277Volt 40-amp Timer...
An electrician installed a new Tork 1103 24 hr timer for the pool pump. You can only manually turn it on and off. When trying to set the time, the dial is loose and does not stay in position and does not...
I think you have 120Volt pool pump.
Add a comment if this is incorrect since wiring information is based on this assumption.
(1) Wiring problem:
Evidence shows timer is wired in reverse (dial only rotates when pump is ON, and dial stops rotating when pool pump is OFF)
Electrician reversed the wires, but wires need to be tested.
Hot wire from circuit breaker always connects to L
Neutral wire from breaker box connects to unmarked terminal.
This will give clock motor continuous power.
Next:
Black wire going to Load (pump) connects to X
White wire going to Load connects to unmarked terminal along with Neutral wire.
Tork 1103 is SPDT timer with 3 watt 120volt clock motor that can control multiple loads and voltages, and can be wired many different ways.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/pdf/1103INSTALLOP.pdf
(2) Loose dial. The dial should only rotate counterclockwise when moved with hand. The fact that trippers work when rotated by hand says dial is probably not problem. If timer is used, and trippers skip over and do not turn on Load (pump) then order P47 replacement trippers.
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Aug 07, 2011 | Hardware & Accessories
Timer wheel seems to slip. Won't hold time
You posted under Intermatic T104 timer.
If you have different timer, information below may not fit your timer.
Add a comment with correct timer brand and model number.
1) Click manual override on-off to see if Load turns ON, and that override snaps crisp and clean and is not sluggish or hard to move.
If override is not functioning well, then timer is bad. Buy new timer.
2) If dial is rotating, note current time, and watch if dial is keeping correct time over full day.
If dial is running slow, then buy T100 series 240Volt clock motor for T104 timer.
3) If dial is keeping good time, then tripper might be worn and need replacement
Link below shows Intermatic T100 series parts:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Jan 06, 2011 | Intermatic T104 24h 208-277v Mechanical...
Will not shut off.
Ok is that the correct model number and voltage? Do you have it connected to 208-277 volts? (230V at home) Is the dial turning? Do you have both on and off trippers installed on the dial (they are not the same). If all that is true be sure the two timer motor wires are on the same incomine L1 and L2 terminals so it will run
Jul 31, 2010 | Intermatic T104R 208-277Volt 40-amp Timer...
Intermatic model T1O4R stopped working. time dial does not move
Can you turn the load ON and OFF with the manual switch? If not, the circuit breaker supplying the timer has probably tripped. Turn the breaker OFF, then back ON. Sometimes a breaker will trip, but it looks like it's still ON.
If you are getting 240 volts at the timer from the breaker, and if you can also manually turn the clock dial, then the timer motor is bad.
Dec 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Our intermatic pool pump timer is brand new and is running backward. we bought a second timer and it is also running backward. We had an electrician come out and he can't figure it out either.
You need to check the line voltage being supplied to the timer. It is possible that you have a reversed neutral and common (hot) line providing power to the timer. It is also possible to have another reverse situation with the way the timer is hooked up to the device it is controlling.
Timer motors should only operate in one direction, but if mis-wired, they can operate backwards.
I would need more information about the exact installation you have in order to provide a more thorough diagnois and solution. Info such as is this a 220V-AC installation; is the timer hooked to more than one (1) device (pump, etc.) ; Is there a GFCI breaker on this circuit (there should be!) ; Is this a new installation or a refurbished pool with a new pump & timer?
Please use the "comment" button to supply me with the info requested so I can better address your issue.
Thanks!
Sep 04, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
414 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
