Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
I need to replace the door gasket on my Zanussi ZWF12070W washing machine. What's the best way to...
(More)
I need to replace the door gasket on my Zanussi ZWF12070W washing machine. What's the best way to tackle this problem please?
hi my other halfs mums washing machine stopped mid througha cycle and woudlnt drain after trouble...
(More)
HI MY OTHER HALFS MUMS WASHING MACHINE STOPPED MID THROUGHA CYCLE AND WOUDLNT DRAIN AFTER TROUBLE SHOOTING SHE CLEANED FRONT FILTER AND MY OTHER HALF TOOK BACK OFF AND CHECKED PUMP, HE REMOVED A CLEAR BALL AND IT NOW WONT START A CYCLE AT ALL, ITS QUITE NEW AND ONLY JUST OUT OF GUARANTEE ANY HELP WOULD BE GREATFULLY RECEIVED. THANKS DAWN.
