Question about Toro Lawn Mower With Toro Power Tools
I have 6.5 hp toro mower and the self propelled wheels quit working. I need to know how to fix it - THANKS
Not sure which model you have, but the rear wheel drive that I have, 20070, transmission goes out every year. Toro had a real bad design on that transmission and they know it. They made a change in 2009 models to try and eliminate the problem and also give a lifetime warranty on the transmission. Model years 2006 thru 2008 has a single bearing on a half shaft and the torque of the drive belt is too much for that single bearing. I am on my second replacement and had an extreme conversation with Customer Service. Go past the first level, "Sorry It's Out of Warranty" to supervision and let them know about their product and insist they repair it. This has been going on for a month for me but I think you have to push these manufacturers to do what is right.
Posted on Oct 06, 2009
  • edadamson May 05, 2011
    Identical problem with my three year old Toro.The single upper bearing let go and the bevel gear stripped clean. No lubrication was seen in the sealed bearing.Quite a job to remove the transmission and bearing.I will just junk it due to repair cost $250 plus .The electric start is also in need of repair. Cost to replace battery,drive belt, repair electri start ,transmission replacement far exceeds the replacement costs Toro is junk.Time to go back to Sears
    Problem Solver:
  • 4 Answers
Check to see if the drive belt is still on the transmission pulley 1st
Posted on Oct 05, 2009
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Toro 6.5 self propelled lawnmower stopped self propelling! T
Removed all the debris that had wound around the front wheels and it works again. Thanks for the help.
Sep 03, 2009 | Toro Lawn Mower With Toro Power Tools
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
May 30, 2009 | Toro Garden
Self-propelled feature runs slow and won't pull as it should!
Check the belt tension. There is a spring that holds the tension and connects the gearbox to the mower deck. If it has slipped off the belt will not be tightened properly.
Hope this helps.
May 05, 2009 | Toro Lawn Mower With Toro Power Tools
Quit self propeling stopped suddenly while mowing
Probably needs a new belt. this happens when you use it alot!!
Apr 11, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,730 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
